installing a deck
Old Jun 20, 2004 | 11:33 PM
moka-only's Avatar
installing a deck
Hey
i just recently bought an alpine deck for my 86, i have the surround off, and i also bought a wiring harness for it. i just neet to know what coloured wires are what from the stock deck?
Old Jun 21, 2004 | 09:17 PM
$100T2's Avatar
On the prowl for an FB
What did you get a wiring harness for? The car or the radio? If you bought a harness for the car specifically, it should A) plug right in, and B) tell you which wires are which. If that is not the case, then exercise a bit of common sense: Gray, green, purple, brown are usually speaker wires and come in pairs... Gray would be the + and gray w/ a black stripe would be the - for your speakers...
There will be two power wires... One is red, the other yellow. IIRC, the yellow is the constant power (for things like station memory... It should correlate with your deck) and the red goes to the ignition switch, thus turning on your deck when you turn on your car.
Black is obviously the ground wire. Blue goes to your power antenna to tell it to go up and down.
Remember to disconnect your battery before you do anything to the stereo.
Good luck.
24seven_dada
20
Nov 10, 2018 12:03 PM
sinclair7seven
11
Sep 11, 2015 10:15 AM
astrum
Sep 7, 2015 11:41 PM
Enzo1944
Sep 6, 2015 08:57 AM
