I am so pissed off at the Audi forum right now
Old Jun 14, 2004 | 12:53 AM
Suparslinc's Avatar
It's Back!
Long story short, I ask a simple question. The kind of question I know would be answered ten times over on this board. Checked back a day later, and nobody had even bothered. They were all too busy discussing chips and 18" wheels and fog lights and ground effects. I swear I miss having an RX-7. At least before if I had a problem I could count on some knowledgeable help.
/end rant
http://www.audizine.com/forum/showth...threadid=11704
Old Jun 14, 2004 | 12:55 AM
mazdaverx713b's Avatar
Have RX-7, will restore
just be thankful you aren't a ricer and lso be thankful that if you were a ricer i would suggest molesting your ***** with a cattle prod.
Old Jun 14, 2004 | 12:57 AM
oh, are you getting power to the plug? usually a seat heater works with a switch, not when you turn the heat on. is ther ea switch and does the connector plug into the seat? also, on some models, only the driver's seat was heated.
Old Jun 14, 2004 | 01:04 AM
Suparslinc's Avatar
It's Back!
Yes, there is a switch on the dashboard. And both seats are heated. I would check the plug for a connnection, but I'm not sure what it's for yet
Old Jun 14, 2004 | 01:07 AM
do you have a service manual? look at the drivers seat and compare connectors and connections. check the plug to see if it has power. if not, perhaps if it is the connector fot the power seats, a relay or a small atx fuse has blown for that particular seat.
Old Jun 14, 2004 | 08:33 AM
Hades12's Avatar
Burning Oil-Grinding 3rd
At least you dont have a Mustang. The only post people will reply to is if it has "Flowmaster" in the title, Ask something Techinal and expect to wait a week for any info.
Old Jun 14, 2004 | 10:00 AM
cletus's Avatar
I have quit using/reading the Audi forums for that reason. They just suck now.
I'm doubting that wire is a problem with your heated seat. It very likely could be for the car phone. I'd check the other seat for a similar connection though just to be sure.
Old Jun 14, 2004 | 10:06 AM
Lookieme's Avatar
Cornbread
I can totally relate.
I'm on RacingSouthwest.com and most of the new people there are ricers.
Old Jun 14, 2004 | 02:03 PM
WonkoTheSane's Avatar
Green Flameless
Any of you guys owned a DSM? Yep, most forums are worse than that..
Old Jun 14, 2004 | 03:25 PM
85rotarypower's Avatar
love the braaaap
They are right about one thing, that is deffinately a plug for the car phone or something similar.
wickedrx2
The Bad & Fugly Members
Jun 10, 2021 06:28 PM
