Blinker problem...
Old Jun 13, 2004 | 04:27 PM
FuLLsMoKe's Avatar
"By the beard of Zeus!"
Blinker problem...
I recently dismantled my intake manifold and now my blinkers will only work randomly. Sometimes I fire up the 7 and the blinkers work. Sometimes it won't. I have no clue what goes on in the electrical system but I have checked the fuses and every fuse is fine (there's only one box, under the steering column, right?). I am guessing there is a loose connection (but I hope not) but how did taking off the intake manifold affect my blinkers?
Any ideas?
Thanks,
FS
Old Jun 13, 2004 | 06:21 PM
Shamus's Avatar
RX-7 lover
perhaps you bumped something. For example there is a very large conector under the wiper fluid tank that could be lose. I'd open the hood and start checking all the connections around the intake and around the carb. you may have accidently poped something off.
Old Jun 13, 2004 | 07:01 PM
FuLLsMoKe's Avatar
That connector under the wiper fluid tank controls the pump, right? The pump works and I can spray windshield fluid out just fine... I've checked for any other loose connectors and everything is fine...
FS
Old Jun 14, 2004 | 07:30 PM
FuLLsMoKe's Avatar
OK--update:
Blinkers do not work at all anymore. I have no clue how to even start diagnosing the blinker system. Someone help!
FS
Old Jun 14, 2004 | 07:52 PM
vipernicus42's Avatar
Rotoholic Moderookie
Didja check your blinker fluid?
lol.. sorry man, I couldn't resist!
I'm not sure, but if you have a heynes, you should check the wiring section.. it's not too bad. I've been having trouble with my washer sprayers.. but that's a slightly different area so I don't know what to say.
Check every damn wire you can find around the area where you worked... Other than that I have no clue
Jon
Old Jun 14, 2004 | 07:59 PM
85rotarypower's Avatar
love the braaaap
The flasher unit might have gone out. I would try to test that if possible. I don't know if it can be tested though. You could always pick a new one up at an auto parts store. They aren't too expensive.
Old Jun 14, 2004 | 08:43 PM
FuLLsMoKe's Avatar
Where's that thing located?
I would normally whip out the haynes manual, but it's back at home...
FS
Old Jun 14, 2004 | 08:57 PM
Suparslinc's Avatar
It's Back!
I'm guessing the flasher unit is the blinker assembly itself
Old Jun 14, 2004 | 10:03 PM
FuLLsMoKe's Avatar
Not all 4 could possibly be broken at the same time... right? Isn't there some sort of electronic device hidden under the dash that controls the flashers that could be broken? my hazards won't even work...
FS
Old Jun 14, 2004 | 10:10 PM
hammmy's Avatar
There is a flasher relay under the dash. In the SA22Cs it is located just to the rear of the computer/abacus. Something like $12-14 at your local parts chain. In a SA22C, the replacement will need an alternate method of remounting it, as the unit is physically different from the OEM.
Personally, I would check the fusebox fuses for corrosion, and check turn signal bulbs. I had a bad bulb that kept my signals/hazards from working, which led to an unnecessary flasher relay replacement before I realized it.
-dave
1980 RX-7
Old Jun 15, 2004 | 04:44 PM
FuLLsMoKe's Avatar
I turned on the parking lights and found that both rear lights do not come on. Maybe they burned out--but, if they had burnt out, wouldn't my blinker blink really fast? They always operated at the normal rate (just working and then not working). Anyway, I'm not sure what it means when the back two lights don't work...
FS
Dimcorner
20
Jul 9, 2002 11:36 PM
