Fuel lines on a 12A Turbo
Old Jun 8, 2004 | 05:12 PM
ssglopezvm's Avatar
DRAG RACING
Question Fuel lines on a 12A Turbo
Im in the process of modifying the fuel lines on my 1984 RX7 for better flow.
Engine: 12A Turbo, Carbureted, street ported, 10psi boost, BMW Bosch fuel pump regulated @ 6-35psi.
Questions are:
1. How thick can the lines be?
2. Can I use alluminum lines?
3. Do both.... fuel line and return line have to be the same thickness?.... or does one have to be thicker than the other?
Thanks for your input.
Old Jun 8, 2004 | 06:38 PM
680RWHP12A's Avatar
with those specs and boost level running the stock fuel lines will be big enough..
Old Jun 8, 2004 | 10:13 PM
coldy13's Avatar
Yeah, shutup kid.
Yeah, stock is enough. I ran my nikki setup at 16psi with the stock lines, no problem at all.
If your upgrading, I think the return should be as big or bigger than the feed. It's not seeing as much pressure so if it can't flow enough the extra fuel will pool up in the regulator and make it run way rich.
Old Jun 8, 2004 | 10:50 PM
ssglopezvm's Avatar
DRAG RACING
You see... Ive been told that the return line should be smaller. Who's right?
Old Jun 9, 2004 | 11:37 AM
mwatson184's Avatar
holley guy
return line should be as big as possible (within reason)
Old Jun 9, 2004 | 07:09 PM
ssglopezvm's Avatar
DRAG RACING
I notice this today.....
On stock lines for 12A; the return line is smaller than the intake line.
Old Jun 9, 2004 | 08:27 PM
680RWHP12A's Avatar
yah, the return line is smaller on most cars....
again, your stock lines will be fine
dkwasherexd
May 27, 2017 04:51 AM
