3rd gen: best 4-WAY speakers
Old Jun 7, 2004 | 01:33 PM
whas tha best 4-WAY speakers or speakers to get for a 3rd gen ??? i have a head unit that outputs 50wx4? so whas a good set-up ???
Old Jun 7, 2004 | 01:42 PM
infinitebass's Avatar
texasrxs.org
A 50wx4 stereo means it outputs to FOUR channels, I.E. front right, front left, rear right, rear left, not to a four way speaker...
Old Jun 7, 2004 | 01:47 PM
indeed .. but whas the best quality speakers i can get for that kinda output ???
Old Jun 7, 2004 | 03:15 PM
johnisenglish's Avatar
That's not a special type of output, that's what ANY head-unit that controls two front and two rear speakers is going to have. Its actually less then stock, as the stock headunit has the center speaker channel and the sub if you've got the Bose system.
Old Jun 7, 2004 | 03:22 PM
rynberg's Avatar
Not true. Both stock systems use a center channel amp (not part of the headunit) that gets signal from the front left and right SPEAKER LEVEL feeds. The Bose system does NOT have rear channels but instead has a subwoofer amp (again, not part of the headunit).
4-way speakers have nothing to do with the headunit. Just go to a couple of stores and listen to speakers in your price range. Use the search function.
Old Jun 7, 2004 | 03:36 PM
DCrosby's Avatar
No it's not Turbo'd
What's the signal level going to the center channel !?
Could you use a 4 channel amp and split off the L&R fronts to combine that signal for the center !? Reducing your effective wattage a bit of course, but the center amp shouldn't draw too much...
Or you could split the line level going to the amp, and .... ah nevermind, I'm putting a gauge pod in there anyhow Fuel Pressure, Oil Temp, And EGT maybe
Old Jun 7, 2004 | 04:04 PM
SpeedKing's Avatar
Power Trippin'
Why would you do that for? If you're upgrading to a new audio system in your FD, just forego the center channel speaker; you won't hear it anyway.
Old Jun 7, 2004 | 04:24 PM
i prefer the bose 2 channel speaker that gives out 150 watt plus 4 custom boombox on the rear. that's what i'll do on my RX-7
Old Jun 7, 2004 | 09:13 PM
rajeevx7's Avatar
2 FD's since '98
In My Opinion
Pioneer 4 way 6x9's.
Great power handling and reasonably priced $320/4.
Raj
But, like Ryan said....go listen to some and make a decision.
Old Jun 7, 2004 | 09:40 PM
rajeevx7's Avatar
2 FD's since '98
Forgot to add....IMO.
Raj
Old Jun 7, 2004 | 10:38 PM
SpeedKing's Avatar
Power Trippin'
Originally posted by rajeevx7
In My Opinion
Raj
Why four 6x9s? Front non-BOSE enclosures will only accomodate a shallow 5.25" or 6.5" speaker.
And BTW, that's "rynberg", not Ryan.
Old Jun 8, 2004 | 12:40 AM
PVerdieck's Avatar
Crutchfield lists 5 1/4 for the fronts and 6X8s for the rears.
Old Jun 8, 2004 | 01:21 AM
SpeedKing's Avatar
Power Trippin'
Well, this is an instance where Crutchfield is dead wrong.
I have Boston Acoustics 6.5" SL65 coaxials up front. They are a direct drop-in installation w/ no modification needed to fit. *Note: (I have a non-BOSE car.)
5x7, 6x8, and 6x9 all will fit, however, proper fitment will depend on the magnet size. Check speaker mounting depth before purchase.
Old Jun 8, 2004 | 01:59 PM
i got tha bose stock system .. so wha are tha sizes for tha front and rear speakers??
Old Jun 8, 2004 | 11:38 PM
SpeedKing's Avatar
Power Trippin'
Rears will be the same. Up front, you can go 5.25", however, you'll have to modify the BOSE enclosure to fit the speaker. This site won't let me link the image, but look at the very last pic on the bottom to see what I mean.
http://www.carstereohelp.com/stereor...zRX7FDrPnl.htm
Otherwise, yank the whole BOSE system out and you can put in 6.5"s.
Old Jun 9, 2004 | 02:48 AM
rynberg's Avatar
Yank the bose system, the amps are designed to handle the 1 ohm Bose drivers. They don't have the oomph to drive the typical 4-ohm driver.
Old Jun 9, 2004 | 12:27 PM
so whas tha best 4 WAY speakers to purchase for quality ?!?
Old Jun 9, 2004 | 12:38 PM
SpeedKing's Avatar
Power Trippin'
There's no such thing as "best"; sound is subjective. Some people prefer a "warm" sounding speaker, others, something that's more "sharp". What I like, you may not, and vice versa. Go to your local car audio store, audition all their 4-way speaker sets, and buy whatever sounds the "best" to you.
Old Jun 9, 2004 | 07:13 PM
mzimmers's Avatar
Is there even such thing as a 4-way speaker? It's hard for me to imagine that such a beast would be any better than a good 2- or 3-way anyway, but I've never even heard of a 4-way speaker. I have to think that it would be pretty deep anyway...
Old Jun 9, 2004 | 08:11 PM
rynberg's Avatar
I believe Pioneer makes one. Personally, I don't understand stillmello's obsession with getting a 4-way. A well designed 2-way is going to offer the best sound at the same price point.
Old Jun 9, 2004 | 08:23 PM
oneflytrini's Avatar
Stabbed by a pen
In My Opinion
Raj
Exactly what Raj said. I have them in my car, and its VERY clear at high volumes. Also they are reasonably priced. If you have the money to spend id go with MB Quarts. The Pioneers are just a notch behind the MB's for half the price.
ALI
demetlaw
Oct 2, 2015 06:22 PM
