engine plans - suggestions
Old Jun 6, 2004 | 06:53 PM
The_7's Avatar
Registered Piston Eater
this is my plan for the engine to be put in my FB so far. what do u guys think? suggestions? TIA
GSLSE Rotor Housings
Lapped & Polished 12A Side & Int. Plates
13B EShaft
Ceramic Coated S5 13B Rotors
RB Lightweight Steel Flywheel
RB Hardened Stationary Gears
S5 Front & Rear Counterweights
Large Streetport Intake
Large Streetport Exhaust
All New Seal Springs
Rotary Aviation Apex Seals (2 or 3mm?)
New Side Seals
13BREW Corner Seals & Plugs
New Rotor Oil Seals
Old Jun 6, 2004 | 07:17 PM
wwilliam54's Avatar
it WILL run
what about rx-8 rotors with machined apex seal slots?
Old Jun 6, 2004 | 07:54 PM
The_7's Avatar
is that all that has to be done to make them work? what is actually done in this process?
Old Jun 6, 2004 | 08:11 PM
wwilliam54's Avatar
it WILL run
im not 100% ive, but as far as i know to use them in a regular 13b you use one of the 2 oil control ring grooves on the side and get the apex seal slots machined to work with regular 13b apex seals (rx-8 seals cant handle the peripheral ports IIRC)
Old Jun 6, 2004 | 08:12 PM
The_7's Avatar
i thought about it and decided that im gonna turbo my engine in the future so i would like to keep the compression lower so ill go with the s5 rotors instead
Old Jun 6, 2004 | 08:15 PM
Lotus00's Avatar
What is the compression on the rx-8 rotors? Are they lighter than the lightest rx-7 rotors?
Old Jun 6, 2004 | 08:17 PM
wwilliam54's Avatar
it WILL run
10 to 1
and yuh, they are the lightest
Old Jun 7, 2004 | 02:01 PM
The_7's Avatar
bump
Old Jun 7, 2004 | 02:26 PM
cosmicbang's Avatar
Can't you reduce the compression of the RX-8 rotors?
Old Jun 7, 2004 | 02:30 PM
wwilliam54's Avatar
it WILL run
why, it would be easier just to use s5 rotors
Old Jun 7, 2004 | 10:00 PM
cosmicbang's Avatar
Less weight? I thought you already had the RX-8 rotors, sorry.
Old Jun 11, 2004 | 10:06 PM
The_7's Avatar
so any suggestions?
Old Jun 12, 2004 | 07:50 AM
mar3's Avatar
Administrator
3 mm seals and a 150 shot of nitrous injected from nozzles placed at the bottom bend...
Old Jun 12, 2004 | 08:18 AM
peejay's Avatar
Old [Sch|F]ool
3mm xeals suck ***. The point of going with a 13B is so you can use the later rotors with 2mm seals, so use 'em!
I like the setup (especially the 13B e-shaft - always important to use in a 13B ) but I'd do two things: I'd brew up one of my special exhaust ports instead of (what I assume you refer to) the RB streetport exhaust, which opens waaaaaaaaaaay too early. And I'd use the aluminum flywheel instead of the steel one.
Old Jun 12, 2004 | 10:53 AM
RgrWalker's Avatar
That's the Only thing different between what you are talking about doing than what I did with my engine.
www.swimhurricanes.com/rxpage.htm
Old Jun 12, 2004 | 10:54 AM
RgrWalker's Avatar
fixed it
Old Jun 13, 2004 | 06:54 AM
mar3's Avatar
Administrator
3mm seals and a progressive-control 250 shot of nitrous......obliviates any advantage to 2 mm seals or turbos...
Old Jun 13, 2004 | 12:15 PM
high-RPM's Avatar
RX7 F0RUM > reallife™
just to be pedantic
turbos have the benefit of recycling (otherwise) wasted engergy
and can be tuned to deliver similar / same power for similar / less fuel (depending on the setup)
Old Jun 13, 2004 | 01:37 PM
Jeff20B's Avatar
Lapping = Fapping
I came up with my own exhaust port which also does not open too early. I really like it.
Old Jun 13, 2004 | 02:16 PM
rxseven's Avatar
Special Dark
Loose the ceramic coating on the rotors and just stick with 2mm apex seals. Lots of people have problems when they machine the slots and use aftermarket seals. Not worth the risk.
Old Jun 13, 2004 | 02:50 PM
mar3's Avatar
Administrator
Originally posted by high-RPM
just to be pedantic
Yes, I imagine a $350 turbo kit would do the job quite well........if you could find it or build it...
Old Jun 13, 2004 | 09:06 PM
The_7's Avatar
im not gonna use nitrous
i like the idea of a different exhaust port
so i guess ill use 2mm seals ( why are 3mm bad?)
rxseven, why should i lose the ceramic rotor coating? it boosts the power.
edit: the engine is gonna be n/a for starters and sometime later on ill install a turbo setup. n/a id like to get it tuned to 200 at the wheels, some may think its a little far fetched for a streetport but i think i can do it.
Old Jun 13, 2004 | 09:37 PM
Jeff20B's Avatar
Lapping = Fapping
3mm is bad because 2mm works better at high RPM.
Old Jun 13, 2004 | 09:42 PM
peejay's Avatar
Old [Sch|F]ool
They're also harder on rotor housings and they don't seal as well. (3mm that is)
Strength is a non issue, you won't break apex seals with an N/A engine.
Also, the 3mm's are now absurdly expensive!
streetlegal?
Mar 17, 2022 02:46 PM
Jutta_J
Mar 25, 2017 11:24 PM
cdn
14
Sep 10, 2015 06:23 AM
cdn
2nd Generation Non-Technical and pictures
Aug 11, 2015 08:59 PM
