Fuel Smell in the cockpit
Old Jun 5, 2004 | 07:42 PM
Slammed_GSL's Avatar
Angry Fuel Smell in the cockpit
Ok, need some input from the crew. I know that on hard turns you can starve your FB stock carb(www.yawpower.com) What concerns me is the smell of fuel in the cockpit after the hard turns and drifting.
I am not in a hurry to have my fresh engine get fried by a fuel fire in the engine bay. Is there anything I can do besides get a modified carb? Any advice would be great.
Old Jun 5, 2004 | 08:01 PM
K-Tune's Avatar
FD Daily
i always smell a little gas after i've been hammering on it. i think it's just because it's carburated..
Old Jun 5, 2004 | 08:26 PM
It "only" happens on hard/sliding turns, not on straights or mild/normal cornering.
Old Jun 5, 2004 | 11:13 PM
YapaKanichi's Avatar
Smile Like a Donut
I would think it's normal. Could be flooding it soemhow, what happens when you smell fuel
Old Jun 5, 2004 | 11:49 PM
after the corner it takes about 3-6 seconds and I start smelling it, it doesn't go away for about a minute or so.
Scary when you know the engine is hot and the header can ignite fuel. I have never found any leaking, but with fuel it disapates pretty quick anyway and is hard to nail down.
Old Jun 8, 2004 | 10:11 AM
Bump
Old Jun 8, 2004 | 12:12 PM
Pittdp's Avatar
I had to change my carbon filter under the hood once, it stoped the fuel smell for me. The reason my carbon filter went bad is because I had a bad fuel cap which caused a presure leak in the fuel system.
Old Jun 8, 2004 | 01:56 PM
Thanks for the tip, I got a couple of spares around. Any ideas for a aftermarket version of the Charcoal Canister?
Regards
Old Jun 8, 2004 | 02:55 PM
BigJim's Avatar
trainwreck
Make sure ur fuel cap is completely on and tight. Also make sure u dont have any leaks in your gas tank
Old Jun 8, 2004 | 03:33 PM
Ahhh, so you're thinking there might be some issues with the tank system in the rear.....not a bad thought.
I will check it out, I have been needing a excuse to go to a fuel cell anyway and dump the stock tank so I can have dual exhaust!
Thanks
Old Jun 8, 2004 | 06:34 PM
BigJim's Avatar
trainwreck
When i ran autocross i smelled fuel and it turned out that my fuel cap went on crooked and i hadnt realised it.
Old Jun 8, 2004 | 07:24 PM
Anex 570's Avatar
It Runs!
I had a leaking fuel cap for a long time and didnt know it till I really took sharp turns and it poured out. Its only like $5 at advanced so its easy too.
Old Jun 24, 2004 | 09:47 AM
Well I think I found the problem at the autocross on Sunday, I had fuel leaking from my cap. Thanks for the help guys!
Old Jun 26, 2004 | 04:44 AM
Bolox's Avatar
whats the difference between the stock fuel tank and a fuel cell?
Old Jun 26, 2004 | 06:41 AM
QuagmireMan's Avatar
Registered Offender
fuel cell is like a usually metal box to hold your fuel in. some people keep them inside the car.
Old Jun 26, 2004 | 06:59 AM
lovintha7's Avatar
Suicidal Death Missile
They also have baffles to keep the fuel from sloshing around, and throwing the balance of the car off when the g forces change direction suddenly.
Old Oct 11, 2007 | 03:43 PM
dreamingofRX7's Avatar
anyone got a general location of this filter to change? the car did have a bad fuel cap before i bought it. i saw something mentioned about it in the smog test receipts. and the new cap seems loose too. but mine smells like fuel most of the time, not just on turns. I dont think my leak is in the cap.
Old Oct 11, 2007 | 03:48 PM
trochoid's Avatar
Old Fart Young at Heart
Canister is mounted on the passenger side shock tower, unless you have an SA, then it's integrated into the air cleaner lid.
Old Oct 11, 2007 | 03:59 PM
thanks dude! I have a 84 GSL-SE, 2 days new to me.
Old Oct 11, 2007 | 04:40 PM
glewsRx's Avatar
Bubble Gum's Good
+1.0e9
Old Oct 11, 2007 | 04:53 PM
i thought there might be a notorious component in the engine compartment which can develop a common fuel leak.
Old Oct 12, 2007 | 12:35 AM
mar3's Avatar
Administrator
Not your engine, but for the carb'd 12A's, they're called the stock factory fuel lines as we see ethanol becoming a regular part of everyone's gasoline now...
Old Oct 12, 2007 | 12:56 AM
justint5387's Avatar
CPS Motorsport
This thread was 3 years old
rgordon1979
40
Mar 15, 2022 12:04 PM
sherff
Sep 12, 2015 12:22 PM
whinin
Sep 5, 2015 11:52 PM
