Found out what Anti Det device is.
Old Jun 3, 2004 | 05:37 PM
ZoomZoom's Avatar
SEMI-PRO
Maybe this has already made its rounds. But Voila. Glad i didnt spend 500 bucks on it.
http://www.pg-unlimited.com/index.as...ROD&ProdID=122
Old Jun 3, 2004 | 08:11 PM
peejay's Avatar
Old [Sch|F]ool
Wow, I can make those for a lot less than $450.
I can make them for FREE.
Old Jun 3, 2004 | 08:40 PM
razorback's Avatar
You've Been Punk'd
so they want 450$ for 2 ******* bolts?
Old Jun 3, 2004 | 08:58 PM
peejay's Avatar
Old [Sch|F]ool
Maybe they are Mazda OEM parts, that would explain the price...
Old Jun 3, 2004 | 09:27 PM
razorback's Avatar
You've Been Punk'd
bwhaahah...
Old Jun 3, 2004 | 10:33 PM
CARLiTO_'s Avatar
why would one need those?
Old Jun 3, 2004 | 11:10 PM
Jeff20B's Avatar
Lapping = Fapping
What's so wrong with simply turning off trailing ignition? Why do I need to purchase a couple expensive bolts?
Oh, ok. It's so there won't be a buildup of carbon that could glow hot and break off or mess up my apex seals. Is that really a possiblility in the real world?
Old Jun 3, 2004 | 11:33 PM
diablone's Avatar
https://www.rx7club.com/showthread.p...hreadid=313424
Old Jun 4, 2004 | 12:41 AM
j9fd3s's Avatar
Community Builder
well you can buy a lot of cold spark plugs for $450....
Old Jun 4, 2004 | 01:11 AM
razorback's Avatar
You've Been Punk'd
or bolts..
Old Jun 4, 2004 | 01:32 PM
93redFD's Avatar
If trailing wasnt that needed, why did mazda's race team add a 3 plug up top on 787b? Its that a extra trial plug?
Old Jun 4, 2004 | 01:47 PM
Jeff20B's Avatar
Lapping = Fapping
I think I'll take my chances. Since I'm NA, the only problem I can think of is a carbon buildup that could break off and go into the header.
Old Jun 4, 2004 | 05:37 PM
RETed's Avatar
Lots of people asking my advice on it, but I never knew what they were until now.
Now, I know what the big ***-reaming is for...
Sure, you get incomplete combustion burn due to no trailings, but you also lose power.  The incomplete combustion helps prevent detonation, so they are right - it does work.
Okay, so you get less detonation but also lose power at the same time.
I call this band-aid tuning...
I know of one very well-know shop on the east coast who was offering these things and having their customer signing NDW's - now I know why they didn't want anyone knowing what they were.
-Ted
Old Jun 4, 2004 | 06:01 PM
Jeff20B's Avatar
Lapping = Fapping
Maybe I'll hook up trailing sooner than I thought I would.
Old Jun 4, 2004 | 06:16 PM
RETed's Avatar
The 3rd "far trailing" was used for a little better power and fuel economy.
I think the SAE paper states that normal trailing spark plugs add around 10% of the power output.
Remember, the 787B car was an endurance racer, so fuel economy is a concern.
There's a write-up on all of that, but I remember something like 6% better fuel economy.  On a 24 hour endurance race, the car goes though hundreds if not thousands of gallons of gas.  Fuel stops mean less time on the track.  At this level of racing, even a couple percentage points of fuel economy can mean the difference in a couple places in the end.
-Ted
Old Jun 4, 2004 | 06:34 PM
peejay's Avatar
Old [Sch|F]ool
-Ted
Not just that, but the 24 Hours of LeMans (as well as other races) has a limit as to how much fuel you can use. Running out of your fuel allotment before the 24 hours are up would be a bad thing, unless you were *reeeeeaaaaallllyy* far ahead (doubtful).
That's where the accomplishment was - winning requires not only being reliable, but having excellent fuel economy as well. (Which is why they were running the thing well lean of best power, something you can do with an N/A rotary)
Old Jun 4, 2004 | 06:47 PM
RX794's Avatar
NYC's Loudest FD
You've GOT to be kidding me! Talk about a replacement for bad tuning skills.
Old Jun 4, 2004 | 07:03 PM
Kenku's Avatar
spoon!
Yeah, kind of... well, I don't think I'm going to comment on the things actually.
I think I may go try to make a 3-plug housing though... depends if I get bored of wiring up the car.
Old Jun 5, 2004 | 12:04 AM
Evil Aviator's Avatar
Rotorhead
The R26B rotors were specially designed to work with the 3-plug system. Have fun making new rotors.
Old Jun 5, 2004 | 12:54 AM
Kenku's Avatar
spoon!
Hey, I wouldn't do this stuff if it weren't fun.
At this point, I'm just messing around with the milling machine and dead rotor housings because I can, not because I intend to build it into a working engine. Hell, I should take pictures of the godawful way-too-huge peripheral port I cut for ***** and giggles.
... darn forum. Not showing up that I posted...
Old Jun 5, 2004 | 04:00 AM
RETed's Avatar
Shouldn't be that much of a problem...
Just drill a hole and blockweld the coolant passages.
I guess there might be some worry about getting more than one rotor housing to be identical in far-trailing spark plugs position.
Mazda fired the normal trailing and the far-trailing both at the same time, I believe.
-Ted
Old Jun 7, 2004 | 12:27 PM
Kenku's Avatar
spoon!
-Ted
Essentially what I had in mind, though IIRC from looking at an R26B, there needs to be some other little modifications so that the plug doesn't interfere with the part of the housing by the oil passage.
Identical positioning... well... milling machine! Why yes, I do tend to look at that as a solution to most of my problems.... what a great toy.
Old Jun 7, 2004 | 12:53 PM
banzaitoyota's Avatar
What Subscription?
Store | Company | Contact Us | Order Tracking | Log In
Current News
TRAILPLUG® (MAZDA ROTARY DETONATION PREVENTION)
Update: 06/05/04: Due to overwhelming feedback from the rotary community regarding pricing for this product, we have consulted Danco, Inc in allowing us to reduce the pricing to what appears to be a more reasonable price for this product. We have reduced the price to $150 to meet a lot of requests for better pricing on this product. At the moment we are awaiting key players in the rotary community to post their feedback, whether good or bad on this product. Please check back here for updates.
TrailPlug® HomePage
Old Jun 7, 2004 | 12:58 PM
Liquid Anarchy's Avatar
We come with the Hardcore
oooorrrr you could pull your trailing spark plug wires...
$150... or free... hmmm...
Old Jun 7, 2004 | 02:56 PM
Jeff20B's Avatar
Lapping = Fapping
That's quite a drop in price. I still think it needs to be reduced further to keep it competative with simply pulling your trailing plug wires.
Considering machining costs (nill once it's set up) and material cost (stock is what per foot?), they could do better and still turn a profit.
I am considering buying these so I don't have to hook up trailing. I'll weigh it with the cost of three ignitors and three coils on my NA 20B. Of course that's $150 for two, so I'm going to have to break the bank if I want three. Real tough decision...
Jmolina0163
Oct 3, 2015 10:04 AM
GreyBush
Sep 12, 2015 02:23 AM
Nosferatu
Sep 5, 2015 02:13 PM
