rx7 85 gslse
Old Jun 1, 2004 | 04:37 PM
rxgen1's Avatar
rx7 85 gslse
hey rx owners now i need a starter would this 12a starter work on a 13b and if not why i owne a 85 gslse thanks
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WD1V
Old Jun 1, 2004 | 04:41 PM
rxgen1's Avatar
if that one dont fit would this one thanks
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WD1V
Old Jun 1, 2004 | 05:17 PM
cdrad51's Avatar
Lorem ipsum dolor sit ame
I believe a 12A wouldn't work on a 13B only because of the different flywheel.
Old Jun 1, 2004 | 05:42 PM
bliffle's Avatar
I was told they're interchangeable, and I hope it's true 'cause I got a $15 12a starter to swap into my 13b when I get the enthusasm to go under for the swap.
B
Old Jun 1, 2004 | 06:54 PM
cdrad51's Avatar
B
What, the starters or the flywheels?
Not to rain on your parade, but look at Mazdatrix page on flywheels. Notice 12As and 13Bs are separated.
http://www.mazdatrix.com/flywheel.htm
Old Jun 1, 2004 | 07:34 PM
gsl-se addict's Avatar
Super Moderator
The 12A starter will work fine. I have used on in the past on my SE. The Mazda parts microfiche also list just one number for '85 manual transmission cars.
The only differences are between the auto and manual starters. The starters for the auto transmission cars are a gear reduction drive so it is easy to tell the difference visually. Either one of the starters that you listed appear to be from a manual transmission car, so either one should work.
Old Jun 1, 2004 | 07:44 PM
BigJim's Avatar
trainwreck
I believe the only difference is the cranking speed. Because of the difference in flywheels they used different teething on the starter to accomidate for that. You may crank faster, or slower, but should work i beliefve
Old Jun 1, 2004 | 09:59 PM
rxgen1's Avatar
i dont know who to belive one guy says it will fit another says it wont idk help please
Old Jun 1, 2004 | 10:32 PM
CARLiTO_'s Avatar
It will work, i am using a 13b starter on my 12a
Th0m4s
Feb 26, 2019 02:04 AM
auggie463
21
Sep 2, 2015 01:46 PM
