Head light problem
Old May 28, 2004 | 10:17 AM
immanuel__7's Avatar
Head light problem
ok the other day i turn the light on and they work fine, then 2 sec latter they shut off. so i turn them off and back on but the light did not come back up. the only way to get the light up is buy using the manel switch to put them up. but when i test for power theres no power on the wires. dose any one have a clue whats going on?
Old May 28, 2004 | 10:20 AM
Mr BiG G's Avatar
I'll Apex YOUR Seal
old wiring/bad wiring
Old May 28, 2004 | 10:24 AM
do you think it would be ok to take wires from bat to switch then to lights and press the manuel button to lift them up?
Old May 28, 2004 | 10:36 AM
Unsupa's Avatar
Blew my 3rd one 12/8/08
check the fusible links under the hood of the car. they're on the driver side strut tower bar behind the battery. i believe the bottom one deals with that.. i had that problem forever..
Old May 31, 2004 | 08:29 PM
I found my problem its wat the start looking connector beside the battary it had so much corotion on it that there was no more contact thanks guys
Queppa
Nov 18, 2024 03:47 AM
turbo-minivan
69
Feb 4, 2016 12:29 AM
fastsaab
Aug 19, 2015 11:42 AM
gtcd
30
Aug 19, 2015 02:44 AM
