2nd time at the tracks............
Old Nov 8, 2001 | 10:41 AM
Dragueur's Avatar
Exclamation 2nd time at the tracks............
something is WRONG!! i think.......my boost ONLY goes up to 10psi on first gear on the street....at the tracks..it will NEVER hit 10psi..stays at 8 psi all the way through......?????
anyways....
reaction: .644
60': 2.344 (i need help on this)
330': 6.137
1/8: 9.232 mph: 79.862
1000': 11.887
1/4: 14.105 mph: 101.137
hopefully with a BETTER launch....(wheelhop and letting off the gas then flooring again) HOPEFULLY i can break 13s.....
95 Base with Blitz BOV and Blitz tt w/ boost gauge
Old Nov 12, 2001 | 05:49 PM
Styk33's Avatar
Haltech E6K
Exclamation
Hopefully we fixed that problem yesterday and you should be getting 10psi again.
Nothing worse than a cracked crossover tube.
Old Nov 15, 2001 | 09:45 PM
Roy Johnson, Jr's Avatar
Cool
Try a quick burn out (w/o going in the water) and staging at 5,000 rpm when ready to launch. When you take off, ride the clutch a little until you get into wheelspin. When wheelspin is acheived, let out fully on the clutch.
I've acheived repeated 1.9 60' times on street tires with this method (back when I was stock sequential w/ approx. 330 rwhp). Also, I found that I didn't get wheel hop this way either.
If you get this down good, you should see high 8s in the 1/8 and high 13s in the 1/4.
See if this helps.
fidelity101
13
Aug 31, 2015 07:47 PM
TerryD
Aug 23, 2015 07:40 AM
Turblown
Vendor Classifieds
Aug 18, 2015 10:01 PM
