how to remove the 12a flywheel, HELP!
Old May 25, 2004 | 06:56 PM
does anyone know how to remove the flywheel from a 12a? i have to swap flywheels from an 84 motor to an 81 motor (differant fly, differant clutch,..,.) but i cannot get the hue *** bolt off, i even tried a 8 ft cheater bar and no go, is there a trick to this ? please help !
Old May 25, 2004 | 06:57 PM
Jeff20B's Avatar
Lapping = Fapping
Say hello to engine vibration and a dead rear stationary bearing. Who told you you could swap flywheels?
Old May 25, 2004 | 06:58 PM
hey, im ushally a chevy person, this was a favor to a friend, ill tell him to get another engine with the correct flywheel
Old May 25, 2004 | 07:01 PM
i suppose it was a good thing i couldnt get that huge nut off even with my 7ft cheater, mabye ill convince him to get a 5.0
Old May 25, 2004 | 07:03 PM
Jeff20B's Avatar
Lapping = Fapping
Double post.
Old May 25, 2004 | 07:05 PM
Jeff20B's Avatar
Lapping = Fapping
The reason why you can't swap flywheels is because the rotors from the later engines are lighter, and the balance weight of the flywheel matches them. If you install a later flywheel onto an earlier engine, there will be an imbalance and cause damage to the rear bearing.
Tell us what your friend is trying to do and we'll be able to give you some good advice.
A 5.0? In an RX-7? No offense, but... ah screw it. I don't find it very fruitful to try to convince a dyed-in-the-wool boinger person into liking rotaries.
Old May 25, 2004 | 07:09 PM
he just blew the motor in his rx7 (1982 12a), and he needed it swapped, so he brought the car to my place with a new engine in the pass seat (also a 12a, but a newer 12a i guesse), so i ripped the motor out, was gonna swap the clutch, and bam, differant flywheels, and because i know that the differant years have differant spline counts i know that just buying a clutch for that motor wont work because he would need a differant tranny with the matchin spling count
although, do you know if it would be possible to get a differant pressure plate and use that clutch disc, that way the spline count with match the tranny
Old May 25, 2004 | 07:14 PM
Jeff20B's Avatar
Lapping = Fapping
Splines? I'm not sure what you mean. All 12As had the same number of teeth on the ring gear. Just get a 225mm clutch and pressure plate for the later engine and it'll fit fine in the tranny and the starter will work.
If the engine is perhaps an '87 or later Turbo II 13B, then the flywheel won't fit the tranny or starter.
We need more information. Pics would be helpful too.
Old May 25, 2004 | 07:18 PM
peejay's Avatar
Old [Sch|F]ool
All N/A RX-7s have the same input spline...
Old May 25, 2004 | 07:20 PM
the engine is a 12a carbed, he told me it was from an 84, as far as i knew the later (83-85) 12A'S had a larger spline count on the input shaft of the transmission, so the discs were not swappable as far as i knew
i dont know where my dig is so i dont think i can get a pic up
Old May 25, 2004 | 07:24 PM
Jeff20B's Avatar
Lapping = Fapping
Only the 2nd gen cars had two different spline counts. All 1st gens were the same, so you're fine. It sounds like your friend just needs a clutch and pressure plate to match the flywheel on the '84 engine.
Old May 25, 2004 | 07:27 PM
yea, thats what i was thinking of telling him, or try to see if he can trade someone for an older engine (there is guy in our city with many many rx7's)
ill have to see if he has the coin
but thanks for the info, i thought forshure i would need to use the older clutch and fly or tell him to get an older engine
i suppose ill have to wait untill he comes by later tonight to find out the story
Old May 25, 2004 | 07:30 PM
Jeff20B's Avatar
Lapping = Fapping
'83-'85 12As had 225mm clutches. '82 and older 12As had 215mm clutches.
Find out as much info as you can before making a decision.
Old May 25, 2004 | 07:31 PM
peejay's Avatar
Old [Sch|F]ool
YOUR TRANSMISSION WILL BOLT UP TO THAT ENGINE/FL:YWHEEL/CLUTCH.
Sheesh.
Old May 25, 2004 | 07:39 PM
not my decission to make, we will see what he wants to do about it, its his cash and his car
Old May 27, 2004 | 01:38 PM
MicahMan's Avatar
That's Nice!!!!
i did that and you take the nut off and use a flywheel puller and pull it off the put other flywheel on and torque down
Old May 27, 2004 | 01:46 PM
Jeff20B's Avatar
Lapping = Fapping
So what did your friend decide to do?
Old May 29, 2004 | 05:35 AM
jimmyjoejoe's Avatar
I AM A THIEF!! READ THE FEEDBACK SECTION!
here's how to get the flywheel off
get a 600 pound gorilla with a half inch drive impact wrench with a 58 mm socket and have him work on it for a day or two
my advice, keep the motor/flywheel/clutch together. i'm running an 84 motor in my 79, just swap manifolds over. it'll happen just right. oh, btw, be careful with the oil coolers!!!
Old May 29, 2004 | 01:20 PM
Jeff20B's Avatar
Lapping = Fapping
Now some newbie's gonna go buy himself a 58mm socket and it'll be all sloppy on the nut.
Old May 29, 2004 | 03:51 PM
iyaseven's Avatar
how i got my fly wheel nut off was to take a 2 1/2 in=55mm socket with a short breaker bar attached. place a oem jack between the car frame and breaker bar handle and turn, easy. but that won't work on the one engine out of the car already.
Old May 29, 2004 | 06:12 PM
Jeff20B's Avatar
Lapping = Fapping
Just for future reference, the correct size is 54mm but 2 1/8" works fine.
Old May 29, 2004 | 06:20 PM
GavinJuice's Avatar
Leave A Message
I don't know why but i laughed so hard when i read that. haha
Old May 29, 2004 | 11:19 PM
iyaseven's Avatar
thanks Jeff20b, i just finished a clutch job last week. 54mm=2 1/8th, right on.
Old May 29, 2004 | 11:55 PM
faye x7's Avatar
brilliantly stupid
yeah...same here...
sinclair7seven
11
Sep 11, 2015 10:15 AM
risingsunroof82
Sep 7, 2015 01:11 PM
Enzo1944
Sep 6, 2015 08:57 AM
