Haltech Half bridge-port ignition timing questions
Old May 17, 2004 | 04:07 PM
mazpower's Avatar
Slizzard sippin sizzurp
I just rebuilt my stock S4 FC engine using S5 rotors and stationary gears & a half bridge. The car runs good, idles funky but is as good as before under load. I'm nervous because I'm running timing for a series 4 setup but now with the 9:1 rotors and bridge port I think it may be too much.
Anyone have any recommendations on a good timing setup that will be safe with this setup? I've seen Hitman's page about porting and he recommends 20 degrees of advance at 4500, as maximum...should I follow this?
Old May 18, 2004 | 08:10 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
Hitman's timming method is a little more advanced the what is reccommended here in states
From what i understand the fuel available is of a higher quality (just higher octane? im not sure) Never the less i wouldnt reccomend running 20*
ReTed will chim in soon enough and answer the rest of your question
-Jacob
Old May 19, 2004 | 08:22 PM
mazpower's Avatar
Cool, thanks for the info. The one thing about the 20* that Hitman recommends, that may or may not be relevant, is that he recommends that as a base timing figure, and you can go up from there once its on a dyno.
alphawolff
Nov 17, 2015 05:57 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
