Shift Points
Old May 14, 2004 | 03:55 PM
Aaron_M's Avatar
Shift Points
what shift points should i be using when racing?I usually shift at about 6700 and my car is a stock 85 GS.I have been told its safe to shift at 7500 but im not sure i want to take my car that high unless i know its ok
Thanks
Aaron
Old May 14, 2004 | 04:14 PM
Swolbynos's Avatar
Newb
get it dynoed and shift at peak power or a couple hundred past
Old May 14, 2004 | 04:37 PM
FB II's Avatar
well, my peak power was at 7800 rpms with alot less mods and no turbo; but in first gear i shifted at 6,000 and then 2nd gear on i shifted at about 6800.
Old May 14, 2004 | 05:32 PM
joeracer's Avatar
If you have a dyno chart, go to this site and plug in the numbers: http://www.bgsoflex.com/shifter.html
This will tell you the correct shift point. I can tell you that the number will be 8000+.
If you have a freshly rebuilt engine that you don't mind rebuilding, you can shift at 8000 RPM without engine damage. This comes from years of experience by a very large number of Spec-RX7 racers around the country. I've done it myself for 2+ years on my current motor. Don't do this on the street, its not worth the extra wear on the engine. See my response here for my explanation of why you need to rev so high to get the maximum acceleration. If you don't believe me just google on "shift point" for lots of useful information.
Old May 14, 2004 | 05:33 PM
joeracer's Avatar
If you have a freshly rebuilt engine that you don't mind rebuilding, you can shift at 8000 RPM without engine damage. This comes from years of experience by a very large number of Spec-RX7 racers around the country. I've done it myself for 2+ years on my current motor. Don't do this on the street, its not worth the extra wear on the engine. See my response here for my explanation of why you need to rev so high to get the maximum acceleration. If you don't believe me just google "shift point" for lots of useful information.
https://www.rx7club.com/showthread.p...5&pagenumber=3
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
REX7&Z32TT
Sep 14, 2015 08:46 AM
