engine internals question
Old May 13, 2004 | 09:36 PM
projekt's Avatar
why are the center and outer plates iron? do they have to be?
does the rotor housing have an iron insert where the apex seal scrapes like a cylinder liner or is it all aluminum?
Old May 13, 2004 | 10:21 PM
j9fd3s's Avatar
Community Builder
Re: engine internals question
the accounting dept said so. no, and they werent until they tooled up for the r100 in 68.
the rotor housing is cast around a peice of steel bent into the correct shape, and then the steel is chrome plated
Old May 15, 2004 | 09:16 AM
projekt's Avatar
so then it would be possible to make a one piece block as long as you can install the rotors, right?
Old May 15, 2004 | 10:30 AM
peejay's Avatar
Old [Sch|F]ool
The aluminum rotor housing is cast around a sheetmetal insert, which is then hard-chromed for wear resistance.
This was not uncommon back in the day for boingers... many WWII airplane engines had hard-chromed cylinder liners. Then again they were expected to basically run WOT for thousands of hours between overhauls.
Old May 15, 2004 | 12:30 PM
j9fd3s's Avatar
Community Builder
actually some of the old boingers are a steel tube and a another flat peice of steel bent around and welded up to be the water jacket
Old May 18, 2004 | 09:19 PM
MikeC's Avatar
I wouldn't think so. Why would you want to do this?
Old May 26, 2004 | 11:48 PM
Wankel7's Avatar
Haven't we ALL heard this
http://racingbeat.com/resultset.asp?PartNumber=11051
Professorpeanutrx7
Aug 15, 2015 01:38 PM
