Finding temp sender wire
Old May 6, 2004 | 08:48 AM
RotaryRyan's Avatar
DSM
Question Finding temp sender wire
I need to find my stock temp sender wire. I guess it got cut or something.
Where does it come from? The firewall?
Is it a certain color?
Any tips will help
Thanks
Old May 6, 2004 | 08:53 AM
RotaryRyan's Avatar
DSM
And im NOT asking where the sensor thing in the engine is. I need to know where the wire comes out from behind the dash.
Old May 6, 2004 | 09:06 AM
Rx7carl's Avatar
Airflow is my life
Wow, theres a mass of spaghetti under the dash. Wont be easy to find even knowing what color it is. Theres online wiring diagrams for all the years to help you trace it. Good luck.
Old May 6, 2004 | 09:17 AM
BrianHeston's Avatar
Beware Of Squirrely Wrath
According to the wiring diagram for the '82, it should be a solid yellow wire. Not sure if this is the same for '84, but it's worth a shot. Good luck.
Here's a link to the full '84 wiring diagram in PDF format:
http://www.wankel.net/~krwright/file...ingDiagram.pdf --- WARNING this is a 35.3 MB file.
Old May 6, 2004 | 04:59 PM
RotaryRyan's Avatar
DSM
I wasnt planning on going under the dash. I just wanted know if it came out of the firewall somewhere or what.
Old May 6, 2004 | 05:07 PM
Anex 570's Avatar
It Runs!
Yes it goes through the firewall.. It eventually ties into your gauge cluster....
Old May 6, 2004 | 05:11 PM
Well, if the sensor is in the engine bay, and the gauge is in the cabin, then yes, it goes through the firewall. Though I'm not sure what you're going to do about the problem if you don't want to get under there?
Microtech
30
Apr 23, 2016 06:37 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
LMBTG
Aug 15, 2015 01:43 PM
