Is it easy to remove the front bumper?
Old Apr 30, 2004 | 07:51 AM
heb09's Avatar
Gday,
my car recently was backed into with a tow bar and put a nice dent in the front bumper. I want to take it off and send it to the shop instead of giving them my car. Is it easy enuff to do? Do the indicators come off with it? Any help is much appreciated. Series 2 btw.
cheers,
heb.
Old Apr 30, 2004 | 09:07 AM
Tom's Avatar
Tom
Whack 'em and stack 'em
From: Clarksburg/Bridgeport WV- North Central Appalachia
You may be able to fix it yourself if the indentation is not too bad. My front bumper was dented almost dead center (previous owner hit a pole in a parking lot). The plastic shroud that covers the front bumper is easily removed- there are access holes to remove the bolts.
I removed the front shroud and then used the high density foam found in newer bumpers to reform my stock shape. I then placed the shroud back on- used a heat gun to make the original shroud pliable and reformed it to original shape. Really easy to do. Took like 1 hour total. Looks like new and you can't see any indentation.
If you need to remove the steel bumper itself- once you get the shroud off you will see how it is attached. Again- not hard at all. If the steel reinforcement is really dented in- you may be able to heat the steel and put a come-along on it to pull it out, then use the foam as described above to reform it..
Hope this helps.
Old Apr 30, 2004 | 11:30 AM
Rotofire's Avatar
Yea, I'm working on it...
ah yes, but if you need a new one of those bumper supports prepare to sacrafice a small goat and take out a loan to Vic. Brit.
Old Apr 30, 2004 | 12:49 PM
mazdaverx713b's Avatar
Have RX-7, will restore
i would go to a boneyard for that part. the bumper itself is aluminum and its very easy to replace. i wouldn't pay a king's ransom for a new bumper. heck, even someone here would probably give you a good deal on one.
Old Apr 30, 2004 | 12:54 PM
Tom's Avatar
Tom
Oh yeah- the bumper was aluminum, not steel as I stated earlier. Mine pulled back pretty damn easy with a little heat..
I re-formed mine because the paint on the bumper cover was not damaged or cracked.. My repair cost $0.00
Old Apr 30, 2004 | 01:21 PM
faye x7's Avatar
brilliantly stupid
Bumper cover = $600
Bumper Reinforcement = $600
...what a joke...
Old Apr 30, 2004 | 06:27 PM
heb09's Avatar
ok sweet, I'm about to attemp to take it off. I'm not paying for this so I don't care what it costs. As long as its fixed! Thx for your feedback.
Old Apr 30, 2004 | 07:07 PM
heb09's Avatar
I've taken out the two bolts that are vertical under the front bumper. What else needs to be removed? The bumper doesnt want to budge
Old Apr 30, 2004 | 07:22 PM
Rusty Shackleford's Avatar
****ty Tune= Low #'s
my bumper has nicks a chucks out of it like somebody took a ax to it (not that bad though) and i think if u put a new bumper cover on it it would be fine thats what imdoin right now and i dont know y everyone sayin its alot of money at autobodyparts.com u can get a cover for about $130..............later Rusty
Old Apr 30, 2004 | 08:32 PM
heb09's Avatar
well its off w00t! The guys at the shop reckon they can heat it up and bend it back out. Now time to go for a drive and see the temp diff.
heb.
Th0m4s
Feb 26, 2019 02:04 AM
