Tach reading..
Old Apr 27, 2004 | 09:12 AM
Red-Rx7's Avatar
Administrative Me
Tach reading..
What does everyone use to make the tach work with the 20b?
Old Apr 27, 2004 | 10:33 AM
now's Avatar
now
2nd gen is easy to adjust, there is a write up on the
speed shop site but i cant seem to find the url.
i am sure someone will post this url for ya.
matt
Old Apr 27, 2004 | 10:36 AM
Red-Rx7's Avatar
Administrative Me
Matt-
Yeah, I read about the 2nd gen.. but does that work with the 3rd gen? I have a 95, FD3S.
Old Apr 27, 2004 | 11:20 AM
j9fd3s's Avatar
Community Builder
the e11 lets you output the right tach signal, so the stock tach works fine.
Old Apr 27, 2004 | 11:32 AM
felix_is_alive's Avatar
microtech also has an output
Old Apr 27, 2004 | 11:49 AM
Red-Rx7's Avatar
Administrative Me
... Odd.
I use the microtech output as well, but my tach reads double. Any certain setting you need? Doesn't the tach read like a 4cyl or something?
Which color wire is from the tach straight? Am I missing something?
Old Apr 27, 2004 | 01:05 PM
Jeff20B's Avatar
Lapping = Fapping
Stock RX-7 tach reads like a 4 cylinder. 99% of all 20B-capable ECUs will output a 6 cylinder 'signal', but some, like the E11 as j9fd3s mentioned, have a multiplier/divider and can be used on a stock tach without adjustment.
As for me...
Old Apr 27, 2004 | 02:00 PM
Originally posted by Red-Rx7
... Odd.
funny ....its a pretty much plug and play deal .......i`ll check the colour of the wires , i`ll post later...
Old Apr 28, 2004 | 10:26 AM
microtech output: blue/white wire
ecu:yellow/blue plug #2b (from dash harness)
Old Apr 28, 2004 | 01:49 PM
Red-Rx7's Avatar
Administrative Me
Yeah.. Did that. Doesn't work. Tach reads 1.5 - 2X the actual. Maybe I need a converter? Ideas?
Old Apr 28, 2004 | 02:39 PM
hhmmm, ....let me check what i can come up with
Old Apr 28, 2004 | 08:08 PM
j9fd3s's Avatar
Community Builder
dakota digital makes a converter, its about $80
Old Apr 28, 2004 | 09:51 PM
**** ....now i have doubts about my tach....hhmm better double check that
Old Apr 28, 2004 | 11:43 PM
Evil Aviator's Avatar
Rotorhead
Re: Tach reading..
I have the 9000rpm version of the SPA Tach/Speedo:
http://www.spatechnique.com/product_...-15tachblk.jpg
matt
http://members.tripod.com/~grannys/rx7tachrecal.html
Old Apr 29, 2004 | 12:16 AM
t-von's Avatar
Rotor Head Extreme
Great find. Heres the link:
http://www.dakotadigital.com/Detail....-8/product.htm
Old Apr 29, 2004 | 12:29 AM
Red-Rx7's Avatar
Administrative Me
Awesome!!! Thanks a bunch. That should solve my problem. Kick ***!
Old Apr 29, 2004 | 03:09 PM
j9fd3s's Avatar
Community Builder
the b2600/20b is using it, it took the higher/stonger of the two settings
Old Apr 29, 2004 | 03:29 PM
Red-Rx7's Avatar
Administrative Me
So it took the "output" #1? vs #2? Odd. Wonder why it would require the stronger signal?
Old Apr 29, 2004 | 03:31 PM
Jeff20B's Avatar
Lapping = Fapping
The B2600 came stock with a 4 cylinder, right?
Old Apr 30, 2004 | 12:02 PM
j9fd3s's Avatar
Community Builder
red: dunno
jeff: yessir!
Old Apr 30, 2004 | 12:39 PM
Jeff20B's Avatar
Lapping = Fapping
Ah, no wonder you needed a friend for the tach.
Old Apr 30, 2004 | 03:21 PM
j9fd3s's Avatar
Community Builder
it was either that or shoehorn the cosmo cluster in there, which would have been neat, but it had a burned out flourescent light bulb...
Old May 10, 2004 | 02:45 AM
RotorMotor's Avatar
DRIVE THE ROTARY SPORTS
too bad... i have one
Old May 10, 2004 | 09:55 AM
Red-Rx7's Avatar
Administrative Me
I now use this box. It corrected my tach, and works great.
Thanks,
Mike
