Limited Slip Diff
Old Apr 26, 2004 | 11:53 PM
rotaryracer2005's Avatar
Limited Slip Diff
if i purchased Kaaz 1.5 way lsd for my 89 gxl rx7, will it fit or do i have to get a tII differential housing and driveshaft or what.... tell me whats the dilio
Old Apr 27, 2004 | 12:41 AM
Sponge Bob Square Pants's Avatar
The real question at hand is why did you purchase a part that you are unsure will fit or not?
Old Apr 27, 2004 | 12:46 AM
first of all spongedude, i didnt purchase **** yet, i need information on whether it would fit in the rear diff. housing on a n/a rx7
Old Apr 27, 2004 | 12:51 AM
Ah yes, I missed the "if"
But I don't know the answer so I can't help you out here, good luck
Old Apr 27, 2004 | 12:54 AM
word dogg, go rx7!
Old Apr 27, 2004 | 03:41 AM
RETed's Avatar
I don't think they make an NA application?
-Ted
Old Apr 27, 2004 | 09:25 AM
FarNorthMotoring's Avatar
KAAZ makes one for the Miata, so even if they don't list the one for the N/A FC the Miata one will work.
Old Apr 27, 2004 | 10:34 AM
are you sure or are you guessing, rx7 is a miata on steroids and or totally different cars. will it fit or not?
Old Apr 27, 2004 | 01:20 PM
Crusader_9x's Avatar
your going to have to switcyh out the diff either way i understand it. you can buy the one for the turbo model but it is basically a lsd in itslef so there no point unless you got a shitload of power. Or you can go out and get a miata rear end and kaaz unit and put those in your car. wither way its alot of work, and doesnt the gxl already have a lsd from the factory? i know my 86 gxl did.
Old Apr 27, 2004 | 05:20 PM
no mine is a 89 gxl and those did not come with factory lsd only in the turbo II models, so a miata rear end would fit?
Old Apr 27, 2004 | 08:24 PM
I am 100% sure, thats if you buy it for 94-up Miata. They have the same ring and pinion size. Mazda is a parts bin car company, a lot of parts cross over, hell I have gears out of a late 80s B2600 4X4 front axle is my 85 RX-7
Old Apr 28, 2004 | 12:55 AM
IRPerformance's Avatar
Sponsor
actually most if not all gxl models had limited slip
Old Apr 28, 2004 | 01:19 AM
But being a S5, it has Viscous type which is pretty useless.
Old Apr 28, 2004 | 10:44 AM
well if all s5 have the same kinda lsd then the one in my t2 works fine
Old Apr 28, 2004 | 11:56 PM
really, so my 7 has lsd, hmm. if i jack it up and rotate one of the rear tires the oppisite will move the same direction, or if i didnt have lsd the tire would spin the opposite way?
Old May 1, 2004 | 02:06 AM
Dak's Avatar
Dak
Information Regurgitator
Most S4 GXL's had LSD.Most S5 did not.It's very unlikely you have a LSD in an 89 GXL.Jack it up and see.With the car out of gear when you spin one tire the other will spin the same direction.Open diff the other wheel will turn the opposite dirrection or not at all.Somewhere on here there is a how-to on how to put the Miata Diff in a n/a Rx7 housing.
Old May 1, 2004 | 03:40 PM
i been had, i jacked it up and the tire spins the opposite way. ****
Old May 2, 2004 | 01:39 AM
Dak's Avatar
Dak
Rotary Performance sells a Kaaz LSD for the N/A.It is 880 dollars.
Old May 2, 2004 | 02:39 AM
really, hmm, what years
Old May 2, 2004 | 01:45 PM
It really doesn't matter 84-91 N/A will all fit.
Old May 6, 2004 | 01:45 AM
SPiN Racing's Avatar
Here is a valuable Link with information regarding Miata Trannies.. and a whole slew of parts relating to the Miata RX-7 crossover.
http://members.aol.com/solomiata/Drivetrain.html
When you read through it it is amazing the tons of info... things like:
The 1990-93 rear had 4.30:1 gears and there are no factory alternate ratio's available (an aftermarket 4.875 ratio is available). Mazda OEM Gears currently available new for the later 1994+ differential assembly are 3.636:1, 3.909:1, 4.10:1, 4.30:1, 4.44:1, 4.625, and 4.778. The 4.10:1 and the 4.30:1 came on the 1994-97 and '99+ Miata respectivley (4.10:1 on automatic starting in 2000). The 4.44:1 came as original equipment on 1987-88 4x4 trucks on the front axle and some commercial light duty trucks. The 3.909 came as original equipment on the 79-85 RX-7 12a as well as the 99+ 6-speed Miata. The 3.636:1 came on the 79-82 RWD 626 5-speed and is currently available new on the 2001+ Austrailan 6-speed. The 4.625 and the 4.778 come on the Kia Sportage 4x4 on the front axle. The 4.778 is US spec and the 4.625 is unique to the NZ market. Mazda has discontinued the 3.308 (optional on 82-83 B2000 diesel) gears. Steeper 4.875:1 and 5.125:1 aftermarket gears are available. All gears are interchangable as a set. See also Felix's RX-7 drivetrain interchange page page for older model Mazda ratio info. Ring and pinion tooth counts
James Knox
Oct 5, 2015 07:56 AM
