Importance of pressing In new Bearings...once?
Old Apr 25, 2004 | 01:36 AM
silverrotor's Avatar
Arrow Importance of pressing In new Bearings...once?
So Aaron Cake and I finish Porting the other day. I wanted to go ***** out and get new Stationary Gear and Rotor Bearings...
I wipe the site and lube It. Sure enough - one of the two Stationary Gear Bearings mis-align by means of the Bearings not lining up to the window (approx 3mm out according to the tab at edge of Bearing). It's suggested to deal with It and file the oval wider. I on the other hand suggested to re-press them to get the balance right b'c I'm a PITA...I prefered opposition.
Problem arose...It's suggested that Bearings are to be pressed In ONE time and one time only. Should a second attempt be made - you will sacrifice the structural Integrity which I could see happening to the soft Bearing. So Instead of dealing with It - I toss out the Bearing and I have to order a new one, no big deal.
Has anyone attempted to re-press them and consequently have the Bearings come undone awhile In the Engine? A 101 on Bearings? Regardless, I like to get your take on any experiences and the like. Thanks!
Old Apr 25, 2004 | 04:07 PM
Aaron Cake's Avatar
Engine, Not Motor
My thoughts are that removing and reinstalling the bearing will shave too much off the OD of the new bearing...And it will be difficult to remove the bearing without destroying it. But you knew this.
Old Apr 25, 2004 | 05:03 PM
riceburner1r2001's Avatar
i just toss the rotor away
im not too high on putting in new bearing thats y mazda said just put new rotors n
Old Apr 25, 2004 | 10:53 PM
*So pressing In new Bearings are a one time deal?*
Don't get me going as to why I am Installing new Bearings...thats another story.
Old Apr 26, 2004 | 12:33 PM
Aaron Cake's Avatar
Engine, Not Motor
Stationary gear bearings is what we're talking about...And tossing a rotor just because of a munched bearing seems to be a perfectly good waste of a rotor.
Old Apr 26, 2004 | 02:48 PM
gambone's Avatar
I've done this a few times pressing in bearings, take a squair and trace down a line from the tab on the back side of the bearing. use this line as a site to line up the bearing with the ress in the hub.
Old Apr 26, 2004 | 02:57 PM
Aaron Cake's Avatar
Engine, Not Motor
LOL. That's what was done. It rotated as it was being pressed in.
Old Apr 26, 2004 | 04:54 PM
I used a one touch press for the Rotor Bearings...It was with the Stationary Gear Bearings I used a mechanical press. How It altered along the way Is beyond me. I wiped and oiled the site...marked the line as gambone has suggested.
I think after I preloaded and than applied the press, It may have Inadvertingly caused this with every repetitive reload and apply until the Bearing was completly pressed In.
Whoa! Exhausting question.
Are new Bearings to be pressed In - are they a one time deal? A second time around will deem them no good? Details and such would be an asset right about now. As I mentioned, a new one Is on the way...I'm asking for the sake of knowing. Thanks.
Old Apr 28, 2004 | 05:22 AM
drago86's Avatar
I dont know the real answer but i'd try it, just measure the ID before and after and if its pretty much the same its probably ok,..maybe..
Old May 4, 2004 | 12:28 PM
Andrew's Avatar
I had a nightmare when I tried putting in new bearings against what turned out to be some good advice. I ended up ruining a rotor. I didn't even consider using the new bearings that were pressed out. They don't normally need to be replaced even if they show a little copper.
Old May 12, 2004 | 05:20 PM
yallgotboost's Avatar
there a one time deal thorw it out bu a new one the only 25 30$ if u press it out it will lose its press
Old May 12, 2004 | 11:51 PM
My thoughts exactly. Needless to say I have since ordered a new Bearing and used a hydraulic press.
I shutter to think of tearing down my Engine a second time and to find the Stationary Gear Bearings fused to the E-Shaft yet - a 2nd time.
Old May 13, 2004 | 06:15 PM
yeah haha
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
