Wolf 3D Discuss the Wolf 3D Engine Management System
Wolf 3D my wolf maps
Old Apr 23, 2004 | 02:39 PM
nyt's Avatar
nyt
my wolf maps
heres my current wolf map. I tuned this with a techedge wbo2, a/f ratios are between 10.8 and 11.2 on a stock s4 tII motor. mods listed below
http://www.countercultured.net/pics/fuel.jpg
http://www.countercultured.net/pics/ignition.jpg
http://www.countercultured.net/r4-23-04.wmf <-- my map
Wolf3d V4 ems
freshly rebuilt motor (stock)
to4b turbo w/ vband
hks cast manifold
racing beat exhaust
apexi blow off valve
greddy intercooler and pipe/elbow kit
hks standard wastegate
techedge wideband o2
msd 6a on the leading coils
greddy profec-b spec-II boost controller
apexi turbo timer
autometer boost gauge
autometer af gauge
160lb/hr injectors (1680cc) secondaries
walbro 255lph fuel pump
FD igniter
FD alternator
Optima yellow cap
fuel pulsation damper removed
throttle body mod
egr/acv blockoff
air pump removed
rats nest removed
Old May 5, 2004 | 10:50 AM
nyt's Avatar
nyt
heres an update
http://www.countercultured.net/pics/...8/r5-05-04.wmf
Old May 10, 2004 | 01:55 PM
nyt's Avatar
nyt
another update.
closed loop setup (ran narrowband output to my wolf)
http://www.countercultured.net/pics/...8/r5-10-04.wmf
Old May 23, 2004 | 08:45 PM
getbent69's Avatar
nvt - how much success have you had with the Wolf running closed loop? I've been playing with mine for a few months and it never seems to be that stable.
Old Jun 1, 2004 | 06:24 PM
nyt's Avatar
nyt
its very finicky... hard to setup right.. ill post my latest maps soon with what i have working for me w/ the techedge narrowband simulation output hooked up
Old Jun 7, 2004 | 11:12 AM
nyt's Avatar
nyt
I setup staging. No need for closed loop now. I tuned it to just run at the right a/f ratio now since only the primaries fire before 4k rpm.
I'll post a map with a nice staging setup after another day or 2 of tuning.
Old Jun 8, 2004 | 01:01 AM
nyt's Avatar
nyt
http://www.countercultured.net/pics/...8/06-07-04.wmf
staging at 4k rpm to 80% of the secondaries
secondaries will only fire at 100% at 86% load and above past 4k rpm.
same setup, walbro pump, 1680 secondaries, gt40. this should be good to like 20 psi, need to datalog/tune more.
its no leaner than 12:1 and no richer than 10:1.
at 10psi its almost exactly 11:1 the whole way. ill be working on it more. updates will be posted to anyone who cares.. dont think there is anyone, but *shrug* its a place to keep track of my **** at least.
Old Jun 8, 2004 | 12:26 PM
eViLRotor's Avatar
Brother of the Rotary
Actually, I have been viewing your maps with the V4 software...just like to compare and play with it.
The Wolf has come a long way since my version 3
Old Jun 8, 2004 | 12:42 PM
nyt's Avatar
nyt
yeah. the staging is nice.. load and rpm based... i was havin some fun with that.. i have so much extra fuel in this injector setup as you see... the walbro seems to be doing a good job of flowing it too.. I just made some more updates to my map, but apparently im maxing out my air filter because boost is dropping from 18 psi at 5500 rpm do like 13-14psi at 7000.. i have a filter from baker precision coming already, because the one i have is just old to begin with.. its small and wicked dirty so i imagine thats the problem. 5" base, 4" top, 4" long, 3" inlet. I dont want to test with no filter as im a bit wary of ******* up my new turbo. anyway, once i get filter, ill finish tuning and post the final maps. and ac is nice. <3 wolf aircon support.
Old Jul 18, 2004 | 04:33 PM
Michael Smith's Avatar
I would like to thankyou for your post as it give me and others a IDEA of fuel and ignition curves and how the staging it set. I realise that people including myself have different setups but it really helps us to start the setup of all the auxillary settings away from fuel and ignition.
Thanks
Michael Smith
13bt large extentport
Hiflow S4 ported Turbo
3 inch exhaust
550cc primary
1000cc secondaries
malpassi rising rate 1:1.7 reg
1 x carter prepump
2 x pierburg hf efi pumps
3/8 lines
Keas Jatco tricked 4sp auto
TCE 2700rpm converter
Wolf 3d Version 4
Old Aug 23, 2004 | 03:52 PM
raising arizona's Avatar
Send me your BMX parts
Interesting MAP's.....sorry I'm late responding. What are your prims?
I had 1680 x 4 and went down to 1000cc on the prims...much better on the idle
Old Sep 29, 2004 | 02:18 PM
nyt's Avatar
nyt
sorry for the late reply, im using stock primaries i think with 1680 secondaries. those maps are quite old. ill post my new ones soon. s5 block this time... staging at 4krpm and higher loads bring in more of the secondary injectors (67% and up)
Old Jun 1, 2006 | 04:30 PM
signofinfinity's Avatar
Coyote
back from the dead
nyt, been a while since we seen your inputs here.
Any Updates you came up with?
By any chance you still got a base fuel map for 1000pris and 1680 sec?
Extended Street Port.....
Thanks
George
Old Jun 4, 2006 | 07:00 AM
Lightbulb
Nyt its good to see you are still kicking around we have missed you!!! I hope to see how your new S5 engine goes maybe you could make a video if you get it dynoed!! It would be awesome. Your base maps are used by many of us including me to start off and it took the hard work out of the initial setup. As you have done I have shared my map as well but it is still in motion as I sort out things when I get time. I was hoping to start a Map Bank for V4 and V3 Maps anyone object to me starting this??? It would require that your basic mods be included too in the post so that we put the apples with the apples so to speak. If no one has objections I will start the Map post later this week.
Cheers
Michael Smith
Old Jun 5, 2006 | 04:44 PM
Coyote
Very good Idea!!! go for it
I can e mail u a ton of maps...tables etc
its up to you. i think its a very good idea
Old Jul 9, 2006 | 02:47 AM
Coyote
Hows the data base going? did you figure out alot of the tables i sent you?
G
Old Jul 9, 2006 | 07:08 AM
G
Yes I am doing work steadily I had a few setbacks with layout editor I was using but
still going. I have changed the sensor files back to .CSV so it can be used with the old software. I will contact you when I get the site up and you can find all my errors.
Cheers
Michael Smith
Old Jul 9, 2006 | 02:51 PM
nyt's Avatar
nyt
Hey, I haven't been driving around too much due to financial issues and other setbacks. A few weeks ago I sent my turbo in for repair (was sitting around with bad bearings for about 5 months). I just got it back, but a part was left out during the rebuild so I had to send it back out again. I get it back monday. I will post my current maps and some datalogs and whatever else once Its running again.
On the bright side, it only takes about 20 minutes to pull/install my turbo =]
Old Jul 11, 2006 | 08:33 AM
Thats Great nyt... Could you also put your mods into the comments so that other know what the map is for...please . I wish I could change my turbo in half a day and keep all the skin too. Its a bit tight in the engine bay. I am in the process of building a Map Database/Web site for all you great users of Wolf EFi's. This will eliminate the starting blues because you will know the map was run on a working car that has some of the software issues attended too.
Thanks again nyt!
Cheers
Michael Smith
Old Jul 11, 2006 | 08:36 AM
nyt's Avatar
nyt
Thanks again nyt!
Cheers
Michael Smith
I'll try putting the info in the comments, but with the old software it was truncating it to one character. anyways ill probably end up posting it with the map. I just put the turbo in yesterday, but ups came around 430.. when i got it in and realized that the oil feed had a cracked end it was too late to get another one made up.
I just got the hose now, gonna put it on and play w/ the new wolf software. updates coming soon
Old Jul 11, 2006 | 08:51 AM
Cool... I am hoping to get to the strip on 22nd of this month my mate has a oldtech 3.3litre straight 6 , NA that runs 13.2 @ 103mph I hope to give him a shake on 9PSI but my ride gets scary at about 165 kph on the strip I need bigger brakes. Not too many TII 929 wagons around the World can hit over 90 mph across the quarter. I always have more boost too
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
nismorx7
Power FC Forum
Oct 1, 2015 10:36 AM
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
