Immobilizer
Old Apr 18, 2004 | 10:00 AM
Bolox's Avatar
Immobilizer
just wondering.. where the best two place to install an immobliser (Kill switch)?
they're compolsery over here when you're buying/selling a car.
-Cheers
Old Apr 18, 2004 | 01:52 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
easiest place is at the ignition switch, but the dummest place for it/easy to find and wire around.
Old Apr 18, 2004 | 05:37 PM
nevarmore's Avatar
Hidden inside a compartment such as the glove box, behind-seat storage or center console is good.
If it doesn't have to be acessible from the cabin under the hood right by the battery is perfect.
If you're going racing putting one on the rear bumper is standard in most leagues.
Old Apr 18, 2004 | 10:58 PM
Bolox's Avatar
its a remote immobiliser so i dont have to worry about hiding the switch...
and by law it need two points of intereference (two kill points)..
so ignition is one.. would the fuel pump be another good one?
-Cheers
Old Apr 18, 2004 | 11:27 PM
RotaryRyan's Avatar
DSM
Your car can run for a little bit after you turn of the fuel pump. On a carb anyway.
Old Apr 19, 2004 | 02:43 AM
Bolox's Avatar
how fars a little bit?
Old Apr 19, 2004 | 02:48 AM
MIKE-P-28's Avatar
That depends on how much gas is in the lines and the carb, as well to how much you hit the gas.
Old Apr 19, 2004 | 06:42 AM
RotaryRyan's Avatar
DSM
as far as i know, my car goes about a block or so when I turn off the pump(at normal driving).
Why do you need a kill switch?
Old Apr 19, 2004 | 09:29 AM
Bolox's Avatar
because it's the law in Western Australia that you need to have an immobilizer fitted when you buy or sell a car.
as im just about to buy my 1st 7 i need to put one in it as the guy b4 me hasn't (and its up to the buyer to do it)
so where would be the best 2 place to put it?
ignition switch and....?
-Cheers
Old Apr 19, 2004 | 11:39 AM
nevarmore's Avatar
If its remote, put it on a relay right at the battery. No battery no go.
You'll have to use a relay because I doubt that the immobilizers switch could adequately handle the current from a battery.
zyph3r
Interior / Exterior / Audio
Jan 27, 2013 09:14 PM
.Jacques
Jul 1, 2010 10:23 AM
BC-FD3S
Jan 11, 2009 05:44 PM
Mr rx-7 tt
SE RX-7 Forum
May 10, 2005 07:55 AM
