heat thru the floor boards
Old Apr 15, 2004 | 07:24 PM
O.K Im knew to the RX-7 family and My car has a lot of heat radiating thru the floor boards ,is this normal I do have an exhaust leak rite at the header flange but I wouldnt think it would cause this much heat . temperature of the motor is fine not over heating . Oiling fine to can anyone give me some insite on this?
Old Apr 15, 2004 | 07:29 PM
comradegiant's Avatar
I hate because I'm bored.
How much is a lot? Like enough to melt the carpet? Otherwise, I'd chalk it up to the exhaust leak or the natural tendancy of rotaries to run hot. Just thank whatever you worship that its not like the Triumph my grandfather used to have that ran the exhaust under the floorboard, and through the center console as the sole method of heating the cabin.
Old Apr 15, 2004 | 07:30 PM
BigJim's Avatar
trainwreck
The exhaust from a rotary engine is extremely hot because there is no "by-stroke" where exhaust is not expelled like in a piston engine. Since hot exhaust is expelled constantly, the heat mounts and mounts, making the exhaust get very very hot, very very quick. Since your exhaust is right under the passenger side, you will feel heat comming through the floor. Mine does that, as well as heat from around the shift boot. If its not excessively hot, burns ur hand to touch, then i would say its normal.
Old Apr 15, 2004 | 07:52 PM
Bad doublepost! Arr!
Old Apr 15, 2004 | 08:42 PM
cosmicbang's Avatar
Are your heat shields intact?
Old Apr 16, 2004 | 07:01 AM
thanx for your response guys I dont know if the heat shields are intact or not will check that out when I replace the exhaust . did read that rexs run really hot so I just needed some experianced thoughts thanx agian
Old Apr 16, 2004 | 07:32 AM
Bob Holton's Avatar
recycled teenager
We alwaays said that they are HOT little cars.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
LongDuck
Oct 7, 2015 08:12 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
