tps sensor
Old Apr 15, 2004 | 04:53 PM
riceburner1r2001's Avatar
tps sensor
i just bought a tps testor from mazdatrix and was wondering if i was doing something wrong. i disconnect the tps from my car the idle goes up. i put on the tester and i see no lights go on, is there something i did wrong
Old Apr 15, 2004 | 05:00 PM
LongDuck's Avatar
84SE-EGI helpy-helperton
Need to adjust the TPS - search under 'TPS' and you should get the full rundown.
It's not a 'plug-and-play' accessory, unfortunately.
The gist is that you'll need to set the TPS for the optimum 'center' position at your engine's idle setting so that it can feed a proper signal to the ECU to adjust for fuel injection mapping. (You're talking about an EFI car SE, right?)
Reply back here if you don't find what you're looking for, and I'll give you the whole rundown,
Old Apr 16, 2004 | 05:49 AM
i am having probs period. i adjusted it all over and no lights will light up at all. i know my tps is working cuz i can unplug it and it will change idle. i just want to adjust it, and it is not fluctuating all over the place i want to tune the tps right. any help would be appreciated
Old Apr 16, 2004 | 08:44 AM
riofrio's Avatar
This IS a tasty burger!
yeah I have a similar problem... one of the 2 light bulbs just never ligths, so when I try to adjust the TPS its hard to say how far is too far turning that screw clockwise.... since i will never get to see both lights on simultaneously. So now my TPS adjusting screw is pretty much all the way to the *clockwise* end, which i'm not sure is a good thing.
Old Apr 16, 2004 | 09:34 AM
Northern 7's Avatar
I've never seen an actual tester other than the cheapy i built out of lights bulbs and wire (which works fine BTW)
Longduck is very knowledgable in this area but I'll jump in anyway -
Actually, you don't really need a tester - you can "hear" 2 audiable "clicks" as you adjust the TPS screw. The clicks are about one full turn of the adjusting screw apart. If you have the screw twisted all the way down, start backing it off until you hear the 1st click - that tells you that you are in the range of adjustment - keep twisting (about one full turn) counter clockwise until you hear the 2nd click, you are now on the other side of the adjustment range. You want to be half way between the two clicks - it's that easy.
Note - the ignition has to be on in order to do this test - that means the key turned all the way on without actually starting the car. Secondly, you should warm up the car prior to making any TPS adjustments.
Longduck may want to add or elaborate on this
Old Apr 16, 2004 | 12:49 PM
LongDuck's Avatar
Northern 7 is on the right track, but if you're still at a loss - read this recent thread about TPS adjustment:
https://www.rx7club.com/showthread.p...hreadid=293113
Also, check your light bulbs to make sure one's not burned out - it's always the simplest things. On the 'clicking' - these are your vent and vacuum solenoids, which perform different features, and if they're not in good working order, may not give a good TPS position when you're done.
Building the 2-light TPS adjuster tool is simple, effective, and cheap. Read up on it, build one, and reap the rewards.
Old Apr 16, 2004 | 04:16 PM
i have the llights going but and a big but why are the lights going constantly everwhere i turn it. i plugged it into the green plug if this is correct and i dont know if the tps is bad or what
Old Apr 16, 2004 | 04:36 PM
i forgot to turn off my car to adjust it. duhhhhh
Old Apr 16, 2004 | 05:03 PM
Northern 7's Avatar
Sounds like you finally read the replys to your post
R.O.D
34
Jan 6, 2016 12:09 AM
vish86
Oct 1, 2015 10:04 AM
Donald Hampton
Sep 20, 2015 09:09 PM
