problems
Old Apr 3, 2004 | 03:41 PM
pimpncuba's Avatar
Replaced the Displacement
problems
when i am driving in 2nd gear + at about 3000 rpms my car begins shaking very badly. i have an 84 gsl-se. no clue what is going on. can anyone help?!?!?
Old Apr 3, 2004 | 05:28 PM
rhinor61's Avatar
Mileage on the car?
Modifications to the car?
When did the problem start?
We should have at least the minimum information to work with here, since we can not drive your car.
John
Old Apr 4, 2004 | 02:18 PM
pimpncuba's Avatar
milage is 160,000. modifications-cold air intake-hollowed cats. the problem started about a week ago just out of the blue. i am in college so the car sits for 2-3 days at a time, don't know it that would have anything to do with it. no clue what is going on.......
Old Apr 4, 2004 | 02:24 PM
Red Zipper's Avatar
The propeller shafts are know to go out on these cars and are non-servicable. check yours for end play on the ujoint and if it's loose, have one made from a drive shaft shop (cheapest) or if you have deep pockets, buy a mazda trix.
Old Apr 4, 2004 | 03:55 PM
rhinor61's Avatar
Yes the drive line is a place to look, jack the car up, support it on jack stands on level ground. Pull on the drive line back and forth and see if there is any movement in the u-joints.
Another place to look is see if a wheel weight fell off, but that is more speed sensitive not RPM.
John
Old Apr 4, 2004 | 03:58 PM
Bruceman's Avatar
Rotor Power Rules
Is it only at 3000rpm in 2nd gear?
Does it happen in 4th gear?
Does the vibration get worse or go away as you get faster?
Do you feel the vibration in the steering wheel or is it in the whole car?
Old Apr 4, 2004 | 04:31 PM
pimpncuba's Avatar
the vibration starts at about 3000 rpms in 2nd gear but stays through the rest of the gears. the shaking is only when i push down the gas though. about this drive line....where do i find it under the car? front-back? and where are the u-joints i should be looking for? i don't have my haynes manual with me at school, but if it is in there i can run home this weekend and check that stuff out. how much am i looking to spend if the drive line is bad? thanks
Old Apr 4, 2004 | 04:46 PM
Red Zipper's Avatar
It's between the tranny and rear end, you could get one in junk yard for about $75 w/ no guarentees if you can fin a SE that hasent been picked clean, or $150 from a shop and you are assured a balenced shaft.
Old Apr 4, 2004 | 05:45 PM
pimpncuba's Avatar
that kindof sucks, i was saving up for a header back RB streetport exhaust, guess i will have to put that on hold until tax returns $$$$$$
WyomingTII
Sep 28, 2015 10:32 AM
lnlreaper
Sep 27, 2015 09:59 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
