GT35R Custom
Old Mar 29, 2004 | 09:51 PM
Fulblown's Avatar
GT35R Custom
There was someone with a GT35R on the forum that was customizing their GT35R so that it would use a T4 sized inlet instead of a T3.
ARE YOU FINISHED???
Has anyone else done this with success??
Thanks
Old Mar 30, 2004 | 03:23 AM
Infini IV's Avatar
Microtech Tuning!
Bump.. sounds interesting...
Old Mar 30, 2004 | 11:46 AM
Crusader_9x's Avatar
iif you are talking about what i think you are then they were not succesful. check out www.cheapturbo.com they got a non bb gt35/t4 called the blowzilla. i think it would fit a rotary perfectly. flows just a little bit more air then a t04s/60-1.
Old Mar 30, 2004 | 01:20 PM
Icemastr's Avatar
All Motor
If you are trying to fit a GT35R onto a T4 manifold then you can buy or make a T4 to T3 adapter. Not sure if thats what you want to do.
Old Mar 30, 2004 | 01:23 PM
IRPerformance's Avatar
Sponsor
yea someone was building one, never followed up on it though
Old Mar 30, 2004 | 02:00 PM
eViLRotor's Avatar
Brother of the Rotary
I saw that turbo on there as well. Seems interesting. I wonder how good the Cheapturbo T04R is as well?
Old Jun 4, 2004 | 10:49 PM
Guerillah's Avatar
www.atpturbo.com now makes a t04 housing for the gt35r. Sell your current housing and switch to the t4 and your set.
Old Jun 5, 2004 | 10:37 AM
EricM's Avatar
BUt it's not divided.
Old Jun 5, 2004 | 10:54 AM
Zero R's Avatar
Just in time to die
I'm working on it I'm trying to get garrett to make a 1.0+ divided, but it wont be done for a little while.
Old Jun 10, 2004 | 02:09 AM
Jetlag's Avatar
Fullblown, It might have been me......I'm thinking of doing my own GT3540 turbo kit using the HKS cast manifold with a T3 flange welded to the manifold. I thought that this was the way to go, but I have changed my mind once again. Instead, I'm 99% sure I will be using Pac Performance custom manifold. I'll be down in Pac sometime next month.
Jay
Old Jun 11, 2004 | 10:40 PM
Michael Filippello's Avatar
If I am correct, and sean can double check this, I believe that there is no difference between the t3 housing and the t4 housing option for the GT35r. The only difference is the flange size. After that, the internal size and A/R are the same as the housing that comes stock on the GT35R. This means you can bolt it to a t4 size manifold but you won't get the flow of a t4 housing. This is for people who do not want to use a t4 to t3 adapter. Maybe later on, more a/r's will be available. The Gt40r however uses a full blown T4 housing.
Mike
Old Jun 12, 2004 | 02:23 AM
TNH's Avatar
TNH
You might ask ATP, or Boost Logic, as both offer a GT35R with a T4 housing. Carl
Old Jun 12, 2004 | 02:25 AM
TNH's Avatar
TNH
what the he// I posted, and it came up with someone elses sig...
Old Jun 12, 2004 | 09:13 AM
Zero R's Avatar
Just in time to die
There is no difference between the two you are correct it is essentially the same housing with a T4 footprint, that is all, I am working on them getting a larger divided housing we will see how long it takes them to come through,
Einheri
Oct 7, 2015 12:23 PM
joel(PA)
Oct 4, 2015 06:07 PM
