What's a good target intake temp?
my Commander was showing 30 degrees celsius tonight on a fully-warmed up engine. Is that pretty decent? I'm using an open intake...would opening up the (blocked off) oil cooler section and routing some dryer hose up to my intake help reduce those temps? Weather was a bit chilly tonight....in the 40's
anything in the 30s or 40s is great...I've seen as high as 70 (eep!) while sitting in traffic and the M2 large heat soaks...
Re: Re: What's a good target intake temp?
Originally posted by GoodfellaFD3S
I see that when cruising on the highway when temps are in the 60s. What kind of IC do you have? If stock, then that's pretty damn good.
Stock IC, yeah. It will get up to 50 during the day in stop/n/go traffic but its usually in the 30-40 range. Very strange.
immanuel__7
89
Sep 5, 2015 10:23 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
