Power FC Can't get more than .5 bar on second turbo
Old Oct 26, 2001 | 04:14 PM
Chris Wilson's Avatar
Just fitted a PFC to a jap spec 93 FD3S. No cat, otherwise stock engine. I can control primary boost with the PFC (which is not fitted with its own boost controller by the way), but whatever extremes of setting of boost and duty cycle I try, the second turbo stays resolutely around .5 / .6 bar . Any ideas, i have had the manifolding off and checked most solenoids and hoses, replacing some along the way. Thanks. I am thinking it may be the restrictors in the wastegate line (pills) but I don't have any info on these at all. Where are they, why are there more than one, and I am sure I read some cars don't even have them... help please! BTW, raising boost on stock fuelling is risky I know, but I am more concerened as to why the PFC has no effect on the secondary.
Old Oct 30, 2001 | 01:05 PM
ech's Avatar
ech
doesn't sound like pills. Sounds like a line is bad in the wastegate line - or maybe a solinoid.
Old Nov 1, 2001 | 12:56 PM
Jodeny's Avatar
Indifferent
Youre wastegate pill is not restrictive enough- you need a smaller one.
John
Th0m4s
Feb 26, 2019 02:04 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
