Which way to point sub?
Old Mar 16, 2004 | 12:28 AM
CSMCanuck's Avatar
I just installed a new 8" sub in my FD, and was wondering if I should face it to the cabin or towards the rear? Which way will sound better?
Also should I phase it 0 or 180 degrees.
Thanks
Old Mar 16, 2004 | 02:36 AM
rynberg's Avatar
It won't really make much of a difference which way you aim it. Very low frequencies are omni-directional. The benefits of aiming the sub away from you are that you don't hear cross-over leakage and distortion as easily.
Phase (or more likely, polarity in your case) is completely system dependent. The best way to set it is to play a tone at the cross-over frequency through your entire system. One polarity setting will be louder than the other one. That is the correct setting.
Old Mar 16, 2004 | 05:25 PM
NukeGenius's Avatar
Dim Sum owns you!
I have mine pointing at the glass in the hatch and it sounds good to me.
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
Zinraf
Oct 1, 2015 01:09 PM
Jingkun
Sep 28, 2015 01:53 PM
