Changing Brake Fluid Help?
Old Mar 11, 2004 | 05:21 PM
95FD_VA's Avatar
I am changing the brake fluid and have a question. I am upgrading to super blue dot 4. I have no idea what is in there now, probably some crap a dealship put in there. Should I bleed all the exisiting fluid until its dry and then add the new fluid or should I add the new fluid slowly to the resevior as the old stuff bleeds out? I am worried about mixing unlike types of fluid together.
Thanks
Old Mar 11, 2004 | 05:24 PM
evot23's Avatar
Classy
Bleed til the fluid is clear with the new stuff
Old Mar 11, 2004 | 05:25 PM
jimlab's Avatar
Super Snuggles
https://www.rx7club.com/showthread.p...OT+brake+fluid
Old Mar 11, 2004 | 08:18 PM
alberto_mg's Avatar
NO!
You really need to learn how to bleed brakes before you go anyfurther and screw yourself up.
Old Mar 11, 2004 | 08:40 PM
95FD_VA's Avatar
easy now, I have bled brakes before, just never flushed the whole system before. Just asking for some advice is all. My real concern was just mixing different types of fluids.
Old Mar 13, 2004 | 09:22 PM
Just remove as much old brake fluid as possible from the reservoir, then add the Superblue and bleed the right rear caliper till you have dark blue fluid coming out and no bubbles. Then proceed to the left rear, then front right, then front left doing the same thing, refilling the reservoir as needed. You've got a whole can of Superblue, so you might as well try to use most of it up. Remember to bleed the clutch slave cylinder as well, since the FD uses a single reservoir for both the brakes and clutch. If you have Speedbleeders, you don't want to let the reservoir go dry, as they don't work with lots of air in the lines.
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
Devon300zx
15
Sep 16, 2015 06:57 AM
SCinfidel
Sep 8, 2015 05:36 PM
Frisky Arab
Sep 4, 2015 06:17 PM
