Blue Smoke?
Old Mar 10, 2004 | 01:25 PM
Saner's Avatar
Porn Star
Blue Smoke?
When I start my engine in the morning, a puff of blue smoke comes out.. What is this due to? Bad apex seals?
Old Mar 10, 2004 | 02:23 PM
condensation man..when its warmed up.. does it still smoke? If it does it might be coolant seals..
Old Mar 10, 2004 | 02:37 PM
RX7Wishing's Avatar
BOOOYAHHHH!
hey said blue smoke. not white smoke.. the blue smoke is prolly oil that either your turbo is leaking or you have an oil seal going out. Does your car smoke under high rpms or WOT?
Old Mar 10, 2004 | 04:22 PM
Saner's Avatar
Porn Star
Not that I notice, although I'll make sure in an hour.
Old Mar 10, 2004 | 08:31 PM
RxSeven1's Avatar
oh geezzz, please dont give false info.
blue smoke= oil
white smoke/smells sweet = coolent
white + cold outside + no smell = condensation
Old Mar 10, 2004 | 08:57 PM
sporff's Avatar
well i believe because rotaries inject oil directly into the combustion chamber that there's some extra in there when you shut it off which may burn off when you restart it. that is one possibility. another is leaky turbos. try popping off the pipe coming from the turbo or a pipe around the IC or whatever to see if there's much oil in it. some is ok but excessive is not.
but i'm no expert so dont' take my word.
Old Mar 10, 2004 | 09:11 PM
Saner's Avatar
Porn Star
Thanks, sporff. I'll definitely check that out.
Old Mar 10, 2004 | 09:31 PM
skunks's Avatar
I'm a CF and poop smith
if it goes away after warm up, your fine
Old Mar 10, 2004 | 10:08 PM
cpa7man's Avatar
Racing is life!
Look out the back when u kick in the turbo's. Does it smoke then. If so its a leaky turbo seal. It will smoke upon cold start and at boost.
ls1swap
Jun 3, 2024 03:25 PM
rx7inoregon
Old School and Other Rotary
Oct 1, 2015 12:44 PM
frosty1993
Sep 30, 2015 01:27 PM
dexter snoek
Sep 29, 2015 09:18 AM
