Quick Q about a T04E!
Old Oct 25, 2001 | 02:07 PM
Manolis_D's Avatar
Question Quick Q about a T04E!
Hey everyone...
Is there any way to squeeze a Garrett T04E into an FC without removing the smog pump?
Thanks!,
Manolis
Old Oct 26, 2001 | 05:42 PM
Kurgan's Avatar
Gaijin Racing
I'm not sure if its possible or not, but I have an idea (not really mine, I've seen it done before) for you.
If you need the smog pump to pass visual inspection, nevermind. But if you need the smog pump to pass a sniffer test only, this will work for you.
You can remove the smog pump and then use an electric smog pump from a C4 or C5 corvette. They are sort of expensive, in the $150 price range, but it does the same damn thing. Just hook it up to the inlet on the catalytic converter. Do you have the stock cat? if you do... I'm not sure this will work, but if you have a Bonez high flow cat, I've seen this work (someone I know did it and told me about it, I didn't actuallyu see it) and pass emissions sniffer test by a LONGSHOT.
just some food for thought.
Old Oct 26, 2001 | 05:51 PM
13BAce's Avatar
On a long vacation
Re: Quick Q about a T04E!
Originally posted by piston eater
Hey everyone...
Thanks!,
Manolis
If you make yourt own manifold it will work fine. The HKS cast iron manifold won't allow for the air pump with most turbos. The HKS TO4E kit will set the turbo just like stock.
Old Oct 26, 2001 | 11:58 PM
Manolis_D's Avatar
Thanks!
Thanks for the info on the electric smog pumps / turbo manifolds! -- MUCH appreciated (now i can sleep tonight :-))
Thanks again,
manolis
Logan Reinisch
44
Sep 17, 2018 12:20 PM
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
eplusz
15
Oct 7, 2015 04:04 PM
TeamRuffRacing
Sep 30, 2015 08:13 PM
