fuel pressure regulator
Old Mar 8, 2004 | 03:07 PM
RXBeetle's Avatar
Is is ok to run a the stock nikki carb with an electric fuel pump and an inline fuel pressure regulator? My 81 12A has a return line for teh regulator and I was just wondering if this was entirely necessary. As long as I get the proper pressure at the end of the line I should be fine right?
Old Mar 9, 2004 | 01:50 AM
Darth Linux's Avatar
yes you can run a regulator. If you have a higher pressure fuel pump than stock you definately need one. Just set it for 3 psi. and you'l be alright.
Rotospectre
Mar 28, 2018 03:33 PM
Snoopy FD
Dec 8, 2015 01:45 PM
