HIDs won't go on...
Old Mar 8, 2004 | 01:09 PM
tinfan82's Avatar
HIDs won't go on...
Hi, I have a sleek light kit with HID's (Hella 90mm) but sometimes one of the HID beam wouln't go on. The battery is brand new (optima orange top). I was thinking that it might be my grounding wires. I was wondering what the problem would be? Can someone help me on this?
thanks,
thien phan
Old Mar 8, 2004 | 05:42 PM
BicuspiD's Avatar
Infamous...Butcher...
if sometimes it goes on and sometimes it goes off and its random, id suspect a bad ballast or igniter
I had this problem with my HIDs once, turns out the ballast was bad ( but under warranty!)
Old Mar 8, 2004 | 06:28 PM
tinfan82's Avatar
if something is wrong with the ballast, then it shouldn't go on at all right? Hopefully it's not the ballast. In order for both of them to go on, I have to turn on and off my headlights and once awhile both would come on. Can I please get some more help?
thanks,
thien phan
Old Mar 8, 2004 | 06:55 PM
BicuspiD's Avatar
thanks,
thien phan
Well obviously check your wires and grounds...
Same exact phenomenon I had.. you have to "kick" it a few times before the spark ignites the xenon gas.. much like a bad flourescent light bulb going out.. Either the igniter is faulty or the ballast is not supplying enough energy to igntie it, the bulb seems to be fine...
If you switch the intermittent ballast/igniter to the consistent side, you can confirm its not the wiring..
wthx100
11
Oct 1, 2015 10:23 PM
Red-Dragon_Akuma
Sep 28, 2015 06:09 AM
izzolaw
1st Gen General Discussion
Sep 27, 2015 08:33 PM
