Can glue fix headlight cover?
Old Mar 7, 2004 | 12:36 PM
clint034's Avatar
Below is the inside of a headlight cover.. the 2 thin brackets that you screw into are broken.. would a good application of super glue fix this problem? Or my other option is that I am purchasing various other plastic parts for under front bumper and I could go ahead and buy a good headlight cover, but will the colors match? Also.. what would a cover cost? Thanks.
Old Mar 7, 2004 | 12:43 PM
Juan's Avatar
Im a tall midget.
I just bought a used cover for $40 bux. If your cover only has cracks in the plastic, super glue should work. If youre missing pieces, get another cover. The paint may not match 100% since every car is in different environments and not everyone takes care of the paint.
Old Mar 7, 2004 | 12:53 PM
rajeevx7's Avatar
2 FD's since '98
Yes, it is the best start. I used super glue on my old cover, and reinforced it with strong tape. Each tab was reinforced, and I never had a problem again.
The paint was faded on it, so instead of repaint it I just bought a new one already painted.
Raj
Old Mar 7, 2004 | 12:57 PM
Black97VR4's Avatar
FEARED
Get a FEED or CWest cover.
Old Mar 7, 2004 | 01:20 PM
Mr rx-7 tt's Avatar
rotary sensei
I fixed a buddies with some epoxy...harder than stock. Fill the crack with it and run your thumb down the entire length of the brace. Let it dry.
Old Mar 7, 2004 | 01:29 PM
Rotarded's Avatar
"Challenged" since 1993
JB Weld works well also.
Old Mar 7, 2004 | 01:49 PM
Mitch529's Avatar
use some plastic weld 2 part epoxy that did the trick on mine!
Mitch
Old Mar 7, 2004 | 02:14 PM
oneflytrini's Avatar
Stabbed by a pen
Try some pvc pipe cement. You can get it at your local Home Depot. Mine flew off at 150mph against one of the M3's, and i had to go and buy a new one from the dealer. If i remember it was around $70 for a new one unpainted. Got it painted, and put the pipe cement all over the seams to reinforce it. The covers are now rock solid even at highspeeds. I never had another problem with them
ALI
Old Mar 7, 2004 | 05:24 PM
clint034's Avatar
Thanks guys.. glue it is
Old Mar 7, 2004 | 05:28 PM
adam c's Avatar
Cheap Bastard
I agree. JB weld would be my first choice.
Old Mar 7, 2004 | 05:35 PM
ZeroBanger's Avatar
I used GOOP! automotive glue almost 2 years ago. Its like a silicon type glue. Works great.
Old Mar 7, 2004 | 05:58 PM
XSTransAm's Avatar
Ee / Cpe
my vote is on jb weld... my friend holds one of his side mirrors on his f150 with the stuff, lol.
Old Mar 7, 2004 | 06:01 PM
skunks's Avatar
I'm a CF and poop smith
jb weld works good for me
Old Mar 7, 2004 | 06:08 PM
Recipe7's Avatar
With Life.
i may be having to do the same for my passenger headlight cover. i can see the cracks already, ill probably hit up jb weld.
im guessing you can get these from home depot type stores?
Old Mar 7, 2004 | 06:10 PM
XSTransAm's Avatar
Ee / Cpe
autozone and pepboys carries it too
rgordon1979
40
Mar 15, 2022 12:04 PM
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
Devon300zx
15
Sep 16, 2015 06:57 AM
