changing manual tranny fluid
Old Mar 5, 2004 | 01:03 PM
MicahMan's Avatar
That's Nice!!!!
Question changing manual tranny fluid
on my 83 gsl the drain plug on the botton to drain the fluid out but how do i fill it back up? there is a plug on the side also but how do you get the fluid in? are you suposed to put the new fluid in the side? i dont know so let me know how its done. thanx
Old Mar 5, 2004 | 01:16 PM
Rotofire's Avatar
Yea, I'm working on it...
uhmmmm, i was unaware that manual tranny's had fluid......
Old Mar 5, 2004 | 01:18 PM
RacerX7fb's Avatar
paradox
Tranny.. drain plug on bottom.. fill up on drivers side square plug.
You can get a gear lube pump for a few bucks at an auto parts store.
Old Mar 5, 2004 | 01:19 PM
Rotofire's Avatar
ah, gear lubing, gotcha
Old Mar 5, 2004 | 01:23 PM
MicahMan's Avatar
That's Nice!!!!
a gear lube pump? any type in particular? and what kind of fluid and how much should i put in? how does the whole pump thing work?
Old Mar 5, 2004 | 01:37 PM
1984special's Avatar
So little time and money
Just connect the pump to the bottle, and pump. The fluid will travel up through the plastic tube and fill the tranny. Sounds like you need to do some more reSEARCH...
BTW you can get a pump at any auto-parts store.
Old Mar 5, 2004 | 01:42 PM
81Rex6port13b's Avatar
I Push My Car Real Fast!
yea get the pump and just pump the fluid in. then stick your finger in the hole to see where the fluid level is. you should beable to slide your finger in and tuch the fluid with out bending your finger down.
or you can just fill till it overflows. lol then you know you have enough.
Old Mar 5, 2004 | 01:43 PM
wwilliam54's Avatar
it WILL run
its 90w gear oil
drain it
then fill it up till it starts coming out of the filling hole
Old Mar 5, 2004 | 01:45 PM
also get some nice fluid. dont go cheap you would be suprized what a good fluid can do.
Old Mar 5, 2004 | 01:57 PM
31rx7's Avatar
If you can, go with Redline MTL - I consistently have the best performance in all my street and race cars with it.
Also, you don't have to buy a gear lube pump. Clamp a rubber hose on to the bottle and fish the hose down from the engine bay into the trans fill hole, and let gravity do the rest.
Rich
Old Mar 5, 2004 | 02:23 PM
MicahMan's Avatar
That's Nice!!!!
ya ok 31rx7 the hose sounds like a good idea. so i just fill it up till it starts to come out. got ya. thanx guys. all the help is appreciated
Old Mar 5, 2004 | 02:25 PM
Jeff20B's Avatar
Lapping = Fapping
Just fill it 'til it dribbles out. Park on a level surface or lift the car straight up if you can.
Old Mar 5, 2004 | 02:29 PM
MicahMan's Avatar
That's Nice!!!!
how about NEO synthetic 75-90 tranny and differential gear lube? is that any good. its on mazdatrix.
Old Mar 5, 2004 | 02:43 PM
Jeff20B's Avatar
Lapping = Fapping
Synthetics in the tranny and diff are always a good idea.
Old Mar 5, 2004 | 02:45 PM
MicahMan's Avatar
That's Nice!!!!
i can pick up a bottle for $12 seems pretty cheap
Old Mar 6, 2004 | 07:44 AM
mwpayne's Avatar
Admitted 'rexaholic'
I've had GREAT luck using GM syncromesh (avaliable at any GM dealer) in quieting scratchy syncros. About $9 a quart, you'll need about 2 1/2 quarts.
Old Mar 6, 2004 | 08:09 AM
sa22c_Drifter's Avatar
Yeah thanks for the info dudes, I was gonna post a thread about this too because everytime im doing 4500 on 4th gear and I downshift to third I hear like this grinding sound, but the tranny cacthes third and transfers power so good that the rear tires screech.
Old Mar 6, 2004 | 08:37 AM
MicahMan's Avatar
That's Nice!!!!
ya in 1st 2nd 3rd and 5th i have like a grinding sound too. but not in fourth. i know it is time to change tranny fluid. so i'll look into gm syncromesh thanks for the tip
Old Mar 6, 2004 | 08:42 AM
Synchromesh is synthetic right....given the fact that it starts with s-y-n.
Old Mar 6, 2004 | 10:05 AM
wwilliam54's Avatar
it WILL run
i dont think it is
btw the syn is for syncro
Old Mar 6, 2004 | 10:09 AM
oh ok, got it. But everyone praises amsoil, isn't amsoil the best gear oil to use on the trany and diff.
Old Mar 6, 2004 | 01:54 PM
MicahMan's Avatar
That's Nice!!!!
ya ok i have done some reasearch on the syncromesh and from what i hear it works wonders. i would go with it. im going to try it
Old Mar 8, 2004 | 03:50 AM
7aull's Avatar
RX HVN
Just a note that the FILLER plug (on the side) of the tranny is a tapered-type thread which does NOT need to be reamed into place when re-installing!!! If you do, it will actually spread the thread hole and is a BEAR to remove the next time (I had to pull the starter to get enough leverage and access to remove it the first time I tried!).
Stu Aull
80GS
Old Mar 8, 2004 | 10:58 AM
vipernicus42's Avatar
Rotoholic Moderookie
I picked up RedLine MT-90, that's the BEST stuff you can get for your manual tranny. I think summitracing.com has it, but don't take my word for it. I asked around locally.. Two weeks and a bit of cash later.. It takes two quarts.
Some people use a funnel and a long plastic tube. You put the tube in the fill hole, dropping it down from the engine bay with the hood open. Pour until it starts to dribble out (a partner helps this).
If you get the high-quality stuff, you won't need to change your tranny fluid for quite a while. Then again, your car probably hasn't had a fluid change on the tranny since you bought it, unless you (or the previous owner) have been taking *awesome* care of it.
Jon
Old Mar 10, 2004 | 12:59 PM
MicahMan's Avatar
That's Nice!!!!
forth gear is direct drive. which means when your in 4th the engine rpms are the same os your output.
