RB rear sway bar help needed
Old Mar 4, 2004 | 02:28 PM
Fire85GSLSE's Avatar
Chad Carson
Can someone with a RB adjustable rear sway bar post some pics with it installed on the 7?
Also where is the best position found for a weekend crusier?
Have installed mine but don't think it is on right or mabe I have it set wrong.
Thanks
Old Mar 4, 2004 | 03:13 PM
ddewhurst's Avatar
The sway bar arms should be parallel to the ground. The sway bar arms should have zero preload with you/passengers in the car. If the sway bar arms are short that is as stiff as the bar will be & it will lossen the rear of the car. If the arms are long that is as soft as the bar can be & will help stick the rearend. The shorter the bar arm is there will be less body roll.
David
Old Mar 5, 2004 | 02:36 AM
Chad Carson
thanks david
with no one in the car the arms are sloped toward the ground and when I test drove it, it wanted to kick the rear end out quick on a corner that I had no problems with before.
So with what your telling me in order to get my 7 to stick the corners I need to adjust the sway bar out (making the arms longer).
Thanks for the help
David
Old Mar 5, 2004 | 02:00 PM
ddewhurst's Avatar
If it were my car I would do what needed to be done to have the sway bar arms parallel to the ground FIRST. There are some basics to seting up a car. Try it after they are parallel to the ground, then the longer/shorter set up depending on what it's doing. The more the arms are towards the ground the more affect they have on the bar working improper. Have a pal of similar weight sit in the car.
David
Old Mar 5, 2004 | 05:39 PM
Chad Carson
Sound like a plan. Thanks for the help
Here is a pic (if it loads)
Old Mar 5, 2004 | 05:48 PM
xander's Avatar
Dude, the bar needs to go between the two bushings, not on top of both of them.
Unless I'm totally missing something...
Old Mar 5, 2004 | 08:02 PM
ddewhurst's Avatar
xander is correct the arm should be between the bushings. That will put the arm a little close to parallel to the ground. If the arm is still not parallel to the ground is there any adjustment in the upper bracket that mounts to the chassis ? If not measure the red spacer tube & cut it shorter so that the arm is parallel to the ground. Get new shorter long bolts if required after you cut the tube spacer.
David
Old Mar 6, 2004 | 06:11 AM
Chad Carson
David
Sounds good. For some reason that is the way the stock one was on so I did the same with the rb one.
As for cutting the red tube spacer that is the one that came in the rb kit so I would hope the tube is the correct length. All of this was a goldish metal color so I painted it red to match the front RB sway bar.
I will try all of this this week and see if it handles better.
If anyone has pics please post them. Also did anyone like the under coating?Thanks for the help guys.
Old Mar 6, 2004 | 06:13 AM
Chad Carson
Here is a pic of the car...
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
need RX7
11
Aug 19, 2015 08:27 AM
