powdercoat the hotside?
Old Mar 2, 2004 | 02:19 AM
widebody2's Avatar
addicted to lounge
Was wondering if you can powdercoat the hotside of a turbo? I would like to do something but the jethot is expensive and there is a powder coat place not far from me. Is this a viable option or is there too much heat?
Old Mar 2, 2004 | 02:49 AM
RETed's Avatar
Powdercoat or ceramic coat?
-Ted
Old Mar 2, 2004 | 08:26 AM
jdhuegel1's Avatar
Glug Glug Glug Burp
Hmmm... I'm not sure. I know you have to bake on powdercoat, but the hotside of a turbo might be TOO hot.. 93BlackFD (I think) does Powdercoating.. Maybe you can ask him?
Old Mar 2, 2004 | 09:26 AM
RacerXtreme7's Avatar
NASA geek
Powder coat will drip off and make a mess with the temps of a turbine, even piston turbine housings. NO POWDER COATING! Ceramic will work fine, if its specific for the application.
~Mike..............
Old Mar 2, 2004 | 04:33 PM
dubrc's Avatar
yeah, when you originally bake it on, it's only at 450 deg F. hot turbo=bad
--Paul
Old Mar 2, 2004 | 11:44 PM
widebody2's Avatar
addicted to lounge
figures
Old Mar 3, 2004 | 08:04 AM
jdhuegel1's Avatar
Glug Glug Glug Burp
Jethot is about a hundred bucks for the hotside.. Just for info.
Old Mar 3, 2004 | 08:35 AM
93BlackFD's Avatar
built my own engine
powdercoat will not work
you can contact columbiacoatings.com, they sell a DIY ceramic kit
Old Mar 4, 2004 | 09:11 AM
fastrotaries's Avatar
W. TX chirpin Monkey
have you used the DIY ceramic kit?
Old Mar 6, 2004 | 10:55 PM
rx7raca's Avatar
wHiTe kNiGhT
hey i got a quick question, sense we are on the topic of powdercoating. if you powdercoat the intake manifold, is that bad? im just thinking because it might hold heat in like getting it chrome dipped. let me know if i can because im thinking of doing this.
Old Mar 11, 2004 | 07:04 PM
gleangonzalez's Avatar
I have mine jethot with the ceramic coating and works great and looks good. velvet black finish is the highest temp coating
Old Mar 14, 2004 | 05:05 PM
BoostedRex's Avatar
NorCal 7's Co-founder
Jethot is the way to go. It's not that expensive at all when you consider how great it works. While you're getting the turbine housing coated, you should seriously think about sending off your DP as well. It's amazing at the difference you'll notice in temps under the hood. Then again I'm pretty much paranoid about the heat issue. Never can be too safe.
Zach
eplusz
15
Oct 7, 2015 04:04 PM
