air blower
Old Mar 1, 2004 | 01:27 AM
riceburner1r2001's Avatar
air blower
i have a 85 gsl-se and i was told u can get the blower to blow harder then it is by hooking up another wire. i did have a/c if that matters and if u can where is it located and what color.
thank you
Old Mar 1, 2004 | 02:38 AM
mazdaverx713b's Avatar
Have RX-7, will restore
what blower are you talking about??? the only blower i know of is the fan motor
Old Mar 1, 2004 | 10:38 AM
QuagmireMan's Avatar
Registered Offender
maybe hes talking about wiring open one of the ports/acuators
Old Mar 1, 2004 | 10:44 AM
perhaps. at first i thought he meant air pumping the 5th and 6th ports.
Old Mar 1, 2004 | 11:04 AM
LongDuck's Avatar
84SE-EGI helpy-helperton
If you're talking about the air conditioning fan, the top speed of the fan is straight 12v, so crossing a wire somewhere isn't going to speed up fan flow, only speed up electrical shorts and fires.
The SE has several variable resistance wire coils that are mounted inside the squirrel cage fan assembly. These are mounted there to ensure that they get cooling airflow when the fan is turning. They INCREASE resistance over a standard 12v feed, thereby slowing down the fan motor rotation speed. As you bump the dial setting up closer to "MAX", you are removing resistance from the circuit going from the battery to the motor. On "MAX", you're running 12v.
Occasionally, over time, these resistance coils will break (or can be broken through a clumsy install of a replacement fan and squirrel cage assembly). When this happens, you'll have less variability in speeds, but you'll ALWAYS have Max flow.
If you're talking about something else, please reply back with more information and we'll see what we can come up with. HTH,
Old Mar 1, 2004 | 12:26 PM
bliffle's Avatar
The fan motor will burnout after a long time. Get a replacement at the junkyard. I think a Ford Escort fan can be adapted if they don't have a 7. The fan in my wifes escort looks identical.
B
Old Mar 1, 2004 | 02:03 PM
fan blower
the fan i am talking about is the 1 that blows air to hit me in the face. i was told u can cross a wire and get it going alittle faster.
Old Mar 1, 2004 | 05:55 PM
LongDuck's Avatar
Yeah,... that was BS from whoever told you that. Don't listen to them anymore.
FlatVermin
22
Sep 27, 2015 05:42 AM
