Sponsored by: CARiD
Wheel Conversion
Old Oct 24, 2001 | 04:55 AM
Rob96GTI's Avatar
Newbie
Question Wheel Conversion
Hi, I am currently trying to find a way to convert the wheel pattern on a '85 RX-7 GSL, I am working with the 4 lug pattern, I am trying to
use Front Wheel Drive 4x100 wheels, First, will I be able to fit the 17x7.5" Wheels at stock hieght, second, how do I go about changing the
bolt pattern or using adapters, and what size adapters will I need? I would like to know if there is another vehicle I can swap parts from to
do this swap inexpensively, or if I just need to go with adapters. The wheels I am hoping to use are coming of a '96 VW Golf if that helps
any.
Can anyone help me out? We would like to resolve this issue by the weekend if possible. Thanks guys.
Old Oct 24, 2001 | 09:50 AM
Josepi's Avatar
Despise Enmity
You need the hubs and associated equipment from a 84-85 GSL-SE (13B N/A motor). I think thats 4x114.3 or whatever that measurement is...
Old Oct 24, 2001 | 10:03 AM
Rob96GTI's Avatar
Newbie
uhh, ok
Ok, I am not sure that helps me, 114.3x4 is not 4x100, Won't bolt up, I need 4x100, nothing else, I will run adapters if i have too, as long as I can bolt up FWD 4x100 17" Rims in the end. Any ideas along those lines?
rx7jocke
72
Jun 17, 2016 03:48 AM
