Power FC PFC commander light when out
Old Feb 28, 2004 | 09:42 PM
negative's Avatar
positive
This happen to anyone here? How do if fix this?
Thanks in advance
Old Oct 19, 2005 | 11:15 PM
badass7's Avatar
Pimpin Rotors...and Hoes
Anyone ?? Same just happened to me.
Old Oct 20, 2005 | 10:05 AM
cewrx7r1's Avatar
Eye In The Sky
Since it is a liquid crystall display, it uses some form of backlighting that shines through the display. You would have to take it apart to find out what type of light
source it uses an replace it. Could be a miniture bulb or light emmiting diode.
Old Oct 20, 2005 | 10:42 AM
FastHatch's Avatar
There was a thread how the green backlight can be replaced with a blue one. I think you should find some good info in this thread.
Old Oct 20, 2005 | 07:17 PM
DaleClark's Avatar
RX-7 Bad Ass
There are LED's around the display that light it up - they're VERY tiny and surface mounted, and typically don't fail. I think they have a VERY long life.
Anyhow, it's more likely a bad solder joint or broken electrical connection in the commander. There's definitely not a bulb to blow out in there.
Dale
Old Oct 20, 2005 | 10:34 PM
badass7's Avatar
Dale
I'm thinking this is the case. THe commander is practically new. Will check it out this weekend. Thanks for the replies.
Old Oct 20, 2005 | 11:11 PM
TwinTurbo_SE7EN's Avatar
resU deretsigeR
could also just be loose where it plugs into the ecu itself.
Old Oct 21, 2005 | 12:18 AM
jpandes's Avatar
Mine has gone out and came back one from time to time. I think it's just a loose connection where plugs in.
Old Jul 29, 2009 | 12:46 AM
Bluewind's Avatar
Has anyone found out which wires lead to the backlight of the screen? Mine are out and it's impossible to see the screen in the dark.
Old Mar 8, 2014 | 11:12 AM
Rx7maluco's Avatar
Was there a solution to this problem?? I have no light in the background or on the arrows. Thx. All my wires seems good.
Old Mar 28, 2014 | 10:42 PM
s2kguy17's Avatar
I tried to get a new screen soldered on mine but didn't work, check the green wire on the bottom when taking it apart. If that doesn't work I had someone solder leds on the side of my screen and it worked.
Old Apr 1, 2014 | 11:06 AM
Rx7maluco's Avatar
Thx.. Pics would be great.
Old Apr 3, 2014 | 04:56 PM
s2kguy17's Avatar
This was at night, I can see it clear in person it was just a bad picture but I should of told my buddy to try a colored LED so it wont be as hard to read.
Old Oct 22, 2014 | 01:17 PM
dom187's Avatar
Checkout my comment on
https://www.rx7club.com/power-fc-forum-47/dark-commander-communication-error-oled-commander-1072287/#post11819794
Old Oct 30, 2014 | 05:12 PM
NoPis10's Avatar
Committee Member #2
My sons commander says APEXI the whole time and never goes to the other screens. It was working fine before but from one day to the next this happened...
Any ideas ??
Old Nov 2, 2014 | 07:04 AM
Rx7maluco's Avatar
Any ideas ??
Open the controller it should be a bad connection on the wire that goes to the controller. My wire WAs broken.. simple to solder back on.. good luck.
Old Nov 4, 2014 | 07:08 AM
NoPis10's Avatar
Committee Member #2
Thanks, I will check that out..
24seven_dada
20
Nov 10, 2018 12:03 PM
msilvia
15
Sep 11, 2015 12:13 PM
