89+ turbo motor in 87 turbo body?
Old Oct 23, 2001 | 05:33 PM
86Rx7GXL's Avatar
How hard is this? what all is differant reason is 89-91 jspec engines seem easyer to find who know maybe you guys can help me out
Old Oct 24, 2001 | 05:14 PM
86Rx7GXL's Avatar
bump
Old Oct 24, 2001 | 05:20 PM
fc3s.org's Avatar
OG
Not too hard to do. Replace the ECU and dash along with the wiring harness and engine. The 87-88's in Japan are not around as much as the 89-91's are, so there are more engines from 89-91's.
Old Oct 24, 2001 | 06:34 PM
easy p-cheesy's Avatar
SPORKY
I wish that were the case here! then maybe I could find one for sale in CA.
Old Oct 24, 2001 | 08:24 PM
86Rx7GXL's Avatar
Does the wireing harness that goes up threw the dash need t be replaced to? of just the one that runs threw the fire wall on the passernger side that goes to the computer and other conections
Old Oct 28, 2001 | 12:18 AM
86Rx7GXL's Avatar
Anybody know?
Old Oct 28, 2001 | 01:05 AM
allstyle's Avatar
swap
I have an 88 t II and put the 89+ engine in with no problems. The reason is.....I have the late 88 model with the n333 which can control the injectors (high impedance). The only thing you will not be able to hook up properly is the oil metering pump. Ours came mechanical...89+ is electrical. But no worries. Just use 2cycle premix in your gas tank and you will be fine. Good luck.
Old Oct 28, 2001 | 02:01 AM
TwinCam13BT's Avatar
Ive done many 91 motors in my 87 T2. Email me if you have any questions.
tworotorturbo@yahoo.com PEACE
cristoDathird
28
May 30, 2019 08:47 PM
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
