88 NA, wanna replace mufflers with str8 pipes for now, back press. be ok?
Old Oct 23, 2001 | 05:21 PM
ItsNiceToBurnRice's Avatar
I know I have a Bonez high flow cat, I just wanna cut my mufflers off and weld some straight pipes on for the time being, I dont have 800 bucks to put a whole system on now, plus Im tryin to work out some kinks in the motor. So I just wanna hear some exhaust screamin', will my back pressure be ok so that my ports open? Cause if they wont, then its obviously not worth it. Thanks everyone!
Old Oct 23, 2001 | 05:51 PM
tesla042's Avatar
...You could always tie them open if you want high end..
-Tesla
Old Oct 24, 2001 | 02:53 AM
FC3AZ's Avatar
I like this idea, I might do it myself to get a new sound, and save me MAJOR cash. So, how bout it? Back pressure ok? or no? Thanks....
Old Oct 24, 2001 | 07:37 AM
t_mak@mail.plymouth.edu's Avatar
Your car will be slower with no mufflers
Old Oct 24, 2001 | 07:41 AM
RX-7 GT's Avatar
HyperREV.com
how?
Old Oct 24, 2001 | 07:46 AM
no back pressure
Old Oct 24, 2001 | 08:27 AM
The Ace's Avatar
Greek Power
Talking
Just go here http://www.rotaryengineillustrated.com and all will be explained. NA engines need the backpressure for low end power, while turbos dont need ANY backpressure at all
Old Oct 24, 2001 | 02:05 PM
FC3AZ's Avatar
Well, I do have the complete stock exhaust system( from the header back). The previous owner replaced the 2 or 3 stock cats with one new cat. That still wont provide enough back pressure?
Old Oct 24, 2001 | 04:17 PM
FC3AZ's Avatar
come on now, TTT
Old Oct 24, 2001 | 05:39 PM
hypntyz7's Avatar
The rotary engine does not need or want backpressure to make the most power. However, the intake system was designed upon backpressure. IF you take away the backpressure you have to change your intake(by wiring open the 6 ports) to match. IF you want your intake to remain stock(6 ports) than your exhaust has to remain stock. A NA rotary would be at its strongest with the 6 ports wired open and a totally open exhaust.
Old Oct 24, 2001 | 06:05 PM
Ryde _Or_Die's Avatar
I think the very best performance would be by having no back pressure...but having use of your 6 ports. Open them with your air pump. I will find out how well this works.
Old Oct 25, 2001 | 01:24 AM
FC3AZ's Avatar
Ok, this is what I am askin..........How do high flow muffler designs keep the 6 ports open, if you say with no back pressure they should stay closed? Correct me if I am wrong......High flow mufflers are the same as no mufflers??? I am a tad confused....please help!!!!!!!!
Old Oct 25, 2001 | 03:04 AM
The Ace's Avatar
Greek Power
Talking
In a NA, you need a minimum amount of backpressure to open the 5th and 6th intake port (dont know exactly how much, heard something about 2psi ??). Because your stock exhaust provides much more than that, you can replace with a catback, that can still provide that little bit of backpressure, but not any more! Just the absolute minimum needed for the 6ports. So you still have the funcionality of the 6ports, and you have the highest flowing exhaust possible
PS: Thats why custom exhausts are a possible danger. The designer/maker must calculate this minimum amount of backpressure, and take it into account...
Old Oct 25, 2001 | 01:51 PM
FC3AZ's Avatar
Ok, so let me get all this in perspective.......sorry for annoying some of you.
Stock header, 1 cat, no muffs = no 6 ports
Stock header, stock cats, no muffs = no 6 ports
Stock header, 1 cat, aftermarket muffs = yes 6 ports
Stock header, stock cats, aftermarket muffs = yes 6 ports
??????????? Am I 100% correct????????
Old Oct 25, 2001 | 02:08 PM
Do we even have a stock header? Thought it was just a stock downpipe.
Old Oct 25, 2001 | 02:25 PM
FC3AZ's Avatar
Sorry, got the term wrong...... downpipe/header/manifold/piece o' chit, whatever that thing is under the heat shield.
Th0m4s
Feb 26, 2019 02:04 AM
bb6guy
Old School and Other Rotary
Oct 1, 2018 08:07 AM
sYnth.
Aug 19, 2015 06:27 PM
bb6guy
Aug 12, 2015 03:29 PM
86rxNa
Aug 11, 2015 11:51 AM
