atf helps in more ways then one
Old Oct 22, 2001 | 11:22 PM
rxspeed87's Avatar
well did the atf trick today
that thing smokes like sm'itch. started it up and came back like 20 min later still smoking though almost died down... gave a few revs and it started smoking like crazy again..
the car does seem to have more power though I was not really able to tell... too busy sliding around outside due to the rain...
also you can find all your exhaust leaks with this stuff running through the car :-) found three today.
the car does idle a lot smoother though. no more backfires
I am curious though today my right muffler had the tip. pipe and all come out and now it is a lot louder and deeper sounding. I love it
though I am just curious could this cause any problem now? the muffler is still there just not the pipe that goes through it or the tip
Old Oct 23, 2001 | 01:19 AM
rxspeed87's Avatar
well did a little run since the ground dried off a little
even though I spun the tires again I can tell the car was pulling a lot harder then before the ATF
damn this stuff works wonders...
though this stuff smokes like a bitch
any ideas on the muffler though? will this cause problems?
Old Oct 23, 2001 | 01:43 AM
Ryde _Or_Die's Avatar
How long did you let your car sit for? O ya, how did you (if you did) turn the engine while it was sitting to put more ATF in? Thanks.
And about your question...never heard of any problems to the mufflers, just the cats but I have yet to do the ATF trick myself.
Old Oct 23, 2001 | 01:52 AM
rxspeed87's Avatar
I let the ATF soak for about 18 hours
needed to get around and do a fewthings. as for how I got the motor to turn I just bumped the starter put some in bumped the starter put some more in. and just kept doing that for a few rotations just to make sure there was enough. then I moved on to the front rotor
Old Oct 23, 2001 | 01:56 AM
How exactly do you "bump the starter"? You took the EGI fuse out & turned the key a sec or what? I am not sure what that means. Thanks.
Old Oct 23, 2001 | 02:03 AM
rxspeed87's Avatar
took both the EGI comp and EGI inj fuse out
then I just sat there turned the key for a split second to get it to move a bit then put some ATF in and just kept ondoing that
you have AIM, ICQ or yahoo.
might be a little easier there
AIM = rxspeed87
ICQ = 4116192
yahoo = pokin_wee_willie
though I dont use yahoo much
and damn I thought I was the only one up at all hours of the night reading about the rx-7
Old Oct 23, 2001 | 02:20 AM
Juan's Avatar
Im a tall midget.
i also did the atf treatment. I video taped the smoke from the minute i started my car till it stopped smoking. I can encode it if you guys want :P
Old Oct 23, 2001 | 02:26 AM
rxspeed87's Avatar
that **** was funny as hell
I did it in my camaro once and it was not that bad put a whole thing of ATF fluid in there. but this car just kept smoking and smoking the entire time. I coulda swore the cops or fire dept was going to come and get pissed at me
one thing I would say is if you can do it at night thatwould be the best time
but yeah wan why not
hey with your sixports wired open doyou have any issues on driving the car around town like that?
what kind of MPG are you pulling?
Old Oct 23, 2001 | 05:25 AM
snoopster76's Avatar
Twisted Girl Chaser
great way to turn your motor
instead of using starter, use a ratchet on the main pulley bolt, e-shaft bolt. turn it in 60 degree increaments for each rotor, then you know you have put it in all chambers. you can go out a couple times during the process and turn the motor like that and that will ensure all is getting soaked.
Old Oct 23, 2001 | 07:43 AM
charger-'s Avatar
Re: great way to turn your motor
hmmm. shouldn't you turn it a full 360 degrees for the next rotor face? the rotor spins at 1/3 the rpms of the e-shaft, so one turn to the e-shaft should give you 1/3 turn of the rotor, no?
Old Oct 23, 2001 | 12:35 PM
Twisted Girl Chaser
you are right
forgot about that, when i did mine, bumped the starter, then while working on the car afterward, i thought of the idea. turned the motor over couple times during the soaking that way. thanks for keeping me straight.
Old Oct 23, 2001 | 02:43 PM
jimmyv13's Avatar
Round&Round not Up&Down
I used MMO instead of ATF 'cause it's designed to burn unlike ATF. It still smoked like a bitch, but I haven't heard anything about it bothering cats, not that I have any.
While mine was stewing, I put it in 5th gear and pushed it backwards for a few feet.... and just listened to the motor make a couple of rev's backward. Then I put it in neutral and push it back in the garage where I started. I did this every few hours to slop around the MMO in the opposite direction of the usual rotation. Maybe it helped, maybe it didn't. That's what I did.
It felt like I just got a new engine!!!!!!!
Old Oct 23, 2001 | 02:56 PM
defylogik's Avatar
i guess i didnt put enuf atf into my motor when i did this.. it only smoked for about 5 min, and i saw no power difference.. i guess ill try it again..
scott
Old Oct 23, 2001 | 02:59 PM
Rxmfn7's Avatar
Do a barrel roll!
Hey, sorry I must have missed the original post, what ATF trick are you guys talking about, and could someone explain to me how to do it, or direct me to the original post, thanks.
Old Oct 23, 2001 | 11:26 PM
jimmyv13's Avatar
Do a search containing "ATF trick" and you'll find a shitload of info there.
Old Oct 24, 2001 | 01:00 AM
Juan's Avatar
Im a tall midget.
i got some videos of the night I did the atf treatment but i need some1 to host them. Anyone have some free space?
Old Oct 24, 2001 | 01:54 AM
Juan's Avatar
Im a tall midget.
4.33.217.103 port 21
user: rx7
pass: rx7
the videos are kind of big. this is running of my dsl so my max upload speed is 15k if i can find a faster host then I will put them there. This is what it looks like after you start your car after putting in the ATF. the videos wanrun and wandriving are just videos of me driving my car after the atf treatment. the camera car is a '01 mustang GT. the other videos are of the smoke coming out of my exhaust and some shots of the neighborhood covered in smoke.
Old Oct 24, 2001 | 09:11 AM
Thingol's Avatar
Attn: rxspeed87
Get it replaced now! I had the same thing happen. About 2 days later, I found that the exhaust had been coming out of the muffler (with no tip), and had nicely warped my bumper. Now I need a new one. Fun. I have a more or less stock exhaust, so if yours is modded, it might not have the same prob-but after you run it for a little while stop, and feel the bumper. If it is hot, you are probably going to begin warping it real soon. You can also get on the ground and look under the bumper-there is a nice pattern of melted plastic that the exhaust pushed toward the back of the car.
Old Oct 24, 2001 | 12:52 PM
rxspeed87's Avatar
thats not good
but yeah my exhaust is a RB header to presilencer to the stock catback. so I would figure my temps are prolly higher back there and I do drive like a mad man half the time. who doesn't in ther 7?? but thanx will check that out after a few days to see if it is warping the pumper at all
Queppa
Nov 18, 2024 03:47 AM
Frisky Arab
13
Aug 18, 2015 05:30 PM
CynicalGambit
Aug 17, 2015 10:41 PM
