Haltech Throttle calibrate question
Old Feb 15, 2004 | 11:09 PM
Project84's Avatar
Open up! Search Warrant!
I went to calibrate the throttle and this is how it went. Under the throttle calibrate page with no throttle input, it reads 8%. It said same thing on engine data page. At full throttle it says 75% on both pages. I disconnected the throttle cable and rotated the throttle manually and it still says 75%. On the calibration page, it say to depress throttle and press space bar to continue.
Heres the questions: Should I depress the throttle, release it, then hit the space bar? Or should I hold the throttle down and hit the space bar while holding the throttle? After calibration, shouldn't it read 0% at no throttle input and 100% at full throttle? The sensor is mounted rock solid. The guy who did it has mounted them before and none of them have problems.
Thanks
Old Feb 16, 2004 | 07:07 AM
LTProject's Avatar
Yes, you should hold it at WOT then hit the space bar. Mine goes from 0 to 95, so i would say youve got something wrong.
mike
Old Feb 16, 2004 | 07:16 PM
Project84's Avatar
I unpluged the TPS, plugged it back in, did the calibration again and it worked.
rgordon1979
40
Mar 15, 2022 12:04 PM
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
Nosferatu
Sep 5, 2015 02:13 PM
gabescanlon
Sep 5, 2015 12:09 AM
rx7shirley
Sep 2, 2015 02:11 PM
