Motherf*ckin, d*ck suckin, piece of sh*t sunroof!
Old Oct 22, 2001 | 03:32 AM
ItsNiceToBurnRice's Avatar
My sunroom is stuck, right side goes up about an inch, left side wont budge. And it makes this terrible clicking noise as soon as its done moving its inch. I really only glanced at taking the headliner out to look at it, does it just pull out or something, and after i get that out of the way, can I f*ck around with it?
Old Oct 22, 2001 | 07:07 AM
SureShot's Avatar
Seduced by the DARK SIDE
It uses push/pull nylon gear tapes on each side. Hopefully the left side is just jammed, and you can free it up. They are similar to the radio antenna tape. If you decide to go in from the inside, you have to pull some of the upper interior plastic to remove the headliner. If you remove the assembly, note how the drain tubes go back on. Hope that helps..
