Another Turbo Question
Old Feb 3, 2004 | 10:16 PM
RotaryRyan's Avatar
DSM
Question Another Turbo Question
If I were to make an exhaust header for a 12a turbo, would I have to use both exhaust ports to have the turbo build up enough psi? I wanted to just use one, but didn't know if that would be enough. I didn't know how most of them were.
Thanks for the help.
Old Feb 3, 2004 | 10:40 PM
Stoops417's Avatar
you don't want to use just one, it will make the turbo take longer to spool because its only getting half of the exaust flow/energy. In this case, you should merge both into the turbine inlet. Just curious, why did you want to use only one?
Old Feb 4, 2004 | 04:55 AM
eddierotary's Avatar
back with rotaries
you cant do that, it wont work and by doing that your making one rotor work more that the other and is gonna cost you a engine. you need to use both not one
hotshot2014
Jul 18, 2017 02:30 PM
smikels
Rtek Forum
May 12, 2016 12:34 AM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
