to4e 60-1
Old Oct 19, 2001 | 01:43 AM
RX-7 GT's Avatar
HyperREV.com
to4e 60-1
what is the max hp and flywheel hp this can make? need to figure out injector sizing. only going to be running around 10-15 psi max. what would you guys recommend.
Old Oct 20, 2001 | 12:02 AM
turbostreetfighter's Avatar
60-1
that turbo can produce 415 rwhp@18 psi,i have run this turbo at 32 psi and had no prolems as long as you have a good intercooler it can be done.
run stock primaries , 1300cc secondaries and a pump and you can squeeze enough injector to make up to 400 rwhp. at 15 psi your car should make about 365 rwhp.
Old Oct 20, 2001 | 12:30 AM
RX-7 GT's Avatar
HyperREV.com
thanks streetfighter,
reason for such low psi is im going non-haltech route for awhile. so im only using a 10psi wastegate/pov. i got the fuel stuff down except im going wiht an aic since im not using a haltech. so at that psi wht cc should i use for my 2 additonal injectors?
thanks
brandon
Old Oct 20, 2001 | 02:45 AM
injector size
just go with the 450cc's that should get you to about 12-13 psi
Old Oct 20, 2001 | 03:07 AM
RX-7 GT's Avatar
HyperREV.com
im sorry but at that low of a cc i will blow the bastard
Old Oct 20, 2001 | 03:14 AM
sickboy's Avatar
u can make well over 365 with that turbo at that boost. if im not mistaken Brian Cains car made 425@ 16psi with a To4E 60-1. ill have to ask him tomorrow seeing as hes in town to help me with my project
Old Oct 20, 2001 | 03:36 AM
RX-7 GT's Avatar
HyperREV.com
cool, thanks man! keep me updated on your project too
Old Oct 20, 2001 | 11:21 PM
BOOSTD 7's Avatar
Persona non grata
Well, a T04E 60-1 could be a lot of different things. But even the smaller Hi-Fi (which is what Brain Cain and I both have) can make about 425 rwhp at around 15-16 psi. Streetfighters numbers would be accurate if you need a catalytic converter.
Old Oct 20, 2001 | 11:48 PM
RX-7 GT's Avatar
HyperREV.com
yea i need a cat. im going with 2 1200 cc's for my additionals and a supra tt pump.
Old Oct 21, 2001 | 01:21 AM
crispeed's Avatar
'Tuna'
If you're going to be running only 10psi then 1200cc is too big an injector for the AIC to control. Go with 450 or 550 cc.
crispeed
87TII
9.20@150mph 1/4
5.91@118mph 1/8
651RWHP/520RWTQ
T-72
2600lbs
Old Oct 21, 2001 | 01:27 AM
RX-7 GT's Avatar
HyperREV.com
really? i was talking to chris he said it would be okay? i checked on the rx7.com fuel calculator it says 450 or 550cc's can barely support the 320hp.
i just wanted enough to control the turbos max hp so if i ever want to raise the boost i'll have the right injectors.
Old Oct 21, 2001 | 01:33 AM
vosko's Avatar
Just Call Me Terminator!
you know you are gonna have 6 550cc injectors right ? with aic should be good for 400rwhp (guessing)
Old Oct 21, 2001 | 01:40 AM
RX-7 GT's Avatar
HyperREV.com
well, im not as smart as you guy's but im using the rx7.com's fuel calculator. and going to be using stock primaries/secondaries with 2 addtionals controlled by the aic. here is what i found out, the following sizes with the stock primaries/secondaries at 58% duty cycle (normal) and the 2 additonals at 80%.
2 450cc's 287hp
2 550cc's 310hp
2 720cc's 349hp
2 850cc's 379hp
2 1200cc's 460hp
2 1600cc's 552hp
now those numbers are from the calculator shown in flywheel hp at 80% duty cycle along with the stocks at 58%. please help
Old Oct 21, 2001 | 07:06 AM
RX-7 GT's Avatar
HyperREV.com
well yea, but im not going to be adjusting the stock duty cycles. unless i get a safc. and i dont want anymore **** in my cockpit. im just going to be using haltech aic. if you look above 6 550cc's arent enough
Old Oct 21, 2001 | 10:10 AM
sickboy's Avatar
that fuel calculator on RP's site isnt worth ****. brian was explaining another way to figure how much fuel you'll need just last night, because i brought up the same thing
i'll ask him for you. Also another reason for the high power figures with brians car at said boost is that he runs an air/water IC.
Old Oct 21, 2001 | 05:13 PM
RX-7 GT's Avatar
HyperREV.com
k, thanks man
Old Oct 22, 2001 | 03:14 PM
Megaspeed7's Avatar
Lightbulb WOW, I'm picking the same turbo for my project!
I just got back into rotaries (buying an 86 TII - yes its an 86 TII) and I'm going to run that exact same setup until I get the $ for the haltech. Except I got hold of a 93 full intake and TB and I'm gonna weld up the primary rail with the 850's into the manifold like srx7.com does. I am thinking of going with the MF2 unit due to its adjustability. Seems like a better unit than the rest for about $350.00 But If not, It'll be the haltech AIC.
You wanna go in together and see if we can get a deal on those turbos and or AIC?
I am also not sure if I'm gonna port a motor, or just see how fast I can take a stock 88 1.3L Japanese Turbo motor (with 93 upper intake, and ported lower of course). We'll see. Drop me an email with your setup so we can get some ideas.
Thanks
Patrick Harris
Megaspeed7@aol.com
Old Oct 29, 2001 | 01:31 AM
InitialD FC's Avatar
Hey guys, i got 2 for sale, check it out....
https://www.rx7club.com/vforums/show...threadid=28837
immanuel__7
89
Sep 5, 2015 10:23 AM
apooch
Sep 4, 2015 10:27 AM
Brenhan
Nov 15, 2001 01:39 PM
fc3s94509
Oct 23, 2001 01:31 AM
