What is the difference between the Turbo & NA RB pre-silencers?
Old Oct 18, 2001 | 01:54 PM
HENRX7's Avatar
Speedster
I know that the turbo one doesn't have a backpressure sensing tube, which is good because I don't need it for my 6-port anyway - I am using my air pump to actuate my 6-port. So, will the turbo pre-silencer work on my NA without any problem?
Old Oct 18, 2001 | 02:00 PM
Question 6-port
How do you make your air pump run your 6-ports?
Old Oct 18, 2001 | 02:21 PM
Xentrix's Avatar
Kill Bear
from what i remember after taking my exhaust back from Ridge Tech...
the turbo's was basically a pipe with fittings for the mounts
the NA's have the fittings and a little 'U' shaped pipe that comes off of it.
turbo
nonturbo
Old Oct 18, 2001 | 02:37 PM
HENRX7's Avatar
Speedster
Re: 6-port
I'll post an answer for this on another thread or maybe pm you.
Old Oct 18, 2001 | 02:41 PM
HENRX7's Avatar
Speedster
are you talking about the backpressure sensing tube, which i mentioned on my first post like the one on the picture?
Old Oct 18, 2001 | 02:49 PM
HENRX7's Avatar
Speedster
Old Oct 18, 2001 | 03:16 PM
HAILERS's Avatar
HAILERS
http://www.racingbeat.com/FRmazda2.htm Their site implies that the only difference is the backpressure tube for the N/A. I looked at the above site under exaust components, turbo 86-92.
Old Oct 18, 2001 | 05:43 PM
13BAce's Avatar
On a long vacation
Both presilencers are the same length.
Old Oct 18, 2001 | 07:21 PM
HENRX7's Avatar
Speedster
So I guess the only difference between them is the backpressure tube. What do you guys think, which one is louder, the main cat or the silencer?
Queppa
Nov 18, 2024 03:47 AM
smikels
Rtek Forum
May 12, 2016 12:34 AM
immanuel__7
89
Sep 5, 2015 10:23 AM
