Microtech Matrix Mode
Old Jan 22, 2004 | 08:58 AM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
Matrix Mode
What exactly is this and how is it better than normal mode? I am asking because this mode doesn't need a TPS from what I read in my GM TPS thread. Is it harder to tune or what? From what I understand the TPS is only used to switch from idle to load maps or whatever they are called. Thanks for any input guys!
Santiago
Old Jan 22, 2004 | 02:56 PM
LT8TurboII's Avatar
Matrix mode is the 3d operation of the fuel tables rpm vs load vs Fuel. Matrix mode has RPM maps every 500 rpm.
Normal mode is a 2D mode, with 2 seperate maps, and idle map and a load map. The TPS switches you from idle to load maps.
Old Jan 22, 2004 | 04:47 PM
1987RX7guy's Avatar
Ok so Matrix Mode is better?
Old Jan 23, 2004 | 07:46 AM
LT8TurboII's Avatar
For a street driven car, no doubt, however, I was able to get my car running VERY nicely in normal mode. I and most people recommend getting the car driveable and getting the high load AF ratio close in normal mode, then switch to matrix mode to fine tune things. I did it this way and haven't had anyone in the car yet that could tell that I didn't have the stock ECU in the car.
msilvia
164
Mar 8, 2020 08:00 PM
24seven_dada
20
Nov 10, 2018 12:03 PM
gfd263
Megasquirt Forum
Aug 28, 2016 08:58 PM
befarrer
Sep 22, 2015 09:33 AM
